Adafruit Industries, Essential service and business: NYC – Executive Order 202.6 - Read more. Accepting essential orders - here's how.
has anyone had experiance making a circuit board with its ed
by josheeg on Wed Nov 24, 2010 3:59 pm
has anyone had experiance making a circuit board with its edge being a card connector? I want to make some sensor cards that plug into a surface mount main board card connector.
josheeg
Re: has anyone had experiance making a circuit board with its ed
by gizmohalo on Wed Nov 24, 2010 6:34 pm
gizmohalo
by josheeg on Thu Nov 25, 2010 10:47 am
neat I like instructibles but I made circuit boards using kicad & eagle & batch pcb. So I wondered about making them in thowse programs & thicknesses I should worry about etc.
josheeg
by zener on Thu Nov 25, 2010 2:39 pm
As far as the thickness, it depends on the socket it is going into. Hopefully you have a PN on that. Otherwise you have to figure it out.
zener
by westfw on Sat Nov 27, 2010 4:49 am
Yeah, I've made a couple. These mini-SD "cards" plug into the slot of a "Mattel Juicebox" media viewer; one of the potentially useful linux-based appliances that appeared some time ago. As a couple of people have implied, having an appropriate PCB thickness is pretty important. Too thin is better than too thick; it might be loose and flakey, or need building up with tape or tissue/paper/addition PCB material/etc and superglue, but a too-thick board can permanently damage the mating connector.
It's not too hard; until relatively recently, card-edge connectors were the most common kind around...
westfw
