I am using norvi AE-04 Series https://norvi.lk/wp-content/uploads/202 ... et-V10.pdf
I am using this example:
https://github.com/adafruit/Adafruit_A ... ended.ino
ads.begin failed , I tried to intialize the second device 0x49 same result
Any suggestion how to procedd?
void setup(void)
Serial.begin(115200);
Serial.println("Hello!");
// The ADC input range (or gain) can be changed via the following
// functions, but be careful never to exceed VDD +0.3V max, or to
// exceed the upper and lower limits if you adjust the input range!
// Setting these values incorrectly may destroy your ADC!
// ADS1015 ADS1115
// ads.setGain(GAIN_TWOTHIRDS); // 2/3x gain +/- 6.144V 1 bit = 3mV 0.1875mV (default)
// ads.setGain(GAIN_ONE); // 1x gain +/- 4.096V 1 bit = 2mV 0.125mV
// ads.setGain(GAIN_TWO); // 2x gain +/- 2.048V 1 bit = 1mV 0.0625mV
// ads.setGain(GAIN_FOUR); // 4x gain +/- 1.024V 1 bit = 0.5mV 0.03125mV
// ads.setGain(GAIN_EIGHT); // 8x gain +/- 0.512V 1 bit = 0.25mV 0.015625mV
// ads.setGain(GAIN_SIXTEEN); // 16x gain +/- 0.256V 1 bit = 0.125mV 0.0078125mV
if (!ads.begin()) {
Serial.println("Failed to initialize ADS.");
while (1);
void loop(void)
//https://github.com/adafruit/Adafruit_ADS1X15/blob/2.2.0/examples/singleended/singleended.ino
int16_t adc0 = ads.readADC_SingleEnded(0);
float volts0 = ads.computeVolts(adc0);
Serial.println("Loop: ");
Serial.println(adc0);
delay(1);
