Last week I purchased the Mini PiTFT pihole kit from the Pi Hut in the UK (https://thepihut.com/collections/raspbe ... -soldering). I've contacted them about this issue and they directed me here.
I have been messing about with computers since the 80s, have some linux experience and quite a lot of hardware hacking experience. I'm confident that I've been following the Adafruit Learn guides correctly.
I've started from scratch four times with two different SD cards. Each time I've installed Raspbian Lite using the Raspberry Pi imager, got pi-hole running and followed the piTFT instructions here: https://learn.adafruit.com/adafruit-min ... le-install
I can't get the screen to work or even be seen with i2c. If I take the kernel install route then the console is visible on the screen. If I take the pure python route then the display becomes backlit but nothing ever shows on it.
The eventual outcome is that when I run stats.py I get this:
File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 154, in __probe_for_device
self.i2c.writeto(self.device_address, b"")
File "/usr/local/lib/python3.7/dist-packages/busio.py", line 159, in writeto
return self._i2c.writeto(address, buffer, stop=stop)
File "/usr/local/lib/python3.7/dist-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 49, in writeto
self._i2c_bus.write_bytes(address, buffer[start:end])
File "/usr/local/lib/python3.7/dist-packages/Adafruit_PureIO/smbus.py", line 314, in write_bytes
self._device.write(buf)
OSError: [Errno 121] Remote I/O error
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 160, in __probe_for_device
self.i2c.readfrom_into(self.device_address, result)
File "/usr/local/lib/python3.7/dist-packages/busio.py", line 149, in readfrom_into
return self._i2c.readfrom_into(address, buffer, stop=stop)
File "/usr/local/lib/python3.7/dist-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 56, in readfrom_into
readin = self._i2c_bus.read_bytes(address, end - start)
File "/usr/local/lib/python3.7/dist-packages/Adafruit_PureIO/smbus.py", line 181, in read_bytes
return self._device.read(number)
File "stats.py", line 50, in <module>
disp = adafruit_ssd1306.SSD1306_I2C(128, 32, i2c)
File "/usr/local/lib/python3.7/dist-packages/adafruit_ssd1306.py", line 222, in __init__
self.i2c_device = i2c_device.I2CDevice(i2c, addr)
File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 50, in __init__
self.__probe_for_device()
File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 163, in __probe_for_device
raise ValueError("No I2C device at address: 0x%x" % self.device_address)
ValueError: No I2C device at address: 0x3c
Thanks for your time!
