Dark Saber - Powering off effects and sounds
Blackmagic1138
Post by Blackmagic1138 »
I'm currently building the Dark Saber DIY following the instructions listed on this website. So far in my research I've only seen videos of the saber igniting with sound. But when it is turned off its like flipping a light switch and just turns off with no sounds. I'm new to this coding so is there a way to add a code to gradually turn off the neo pixels from blade tip to hilt and add an "off" sound.
Thanks in advanced.
Blackmagic1138
Re: Dark Saber - Powering off effects and sounds
I found code from the Prop-maker lightsaber build. Hoping that I can use this to animate the blade when turned on/off and play both sounds as well.
# Main program loop, repeats indefinitely
while True:
    red_led.value = True
    if not switch.value:                    # button pressed?
        if mode == 0:                       # If currently off...
            enable.value = True
            power('on', 1.7, False)         # Power up!
            play_wav('idle', loop=True)     # Play background hum sound
            mode = 1                        # ON (idle) mode now
        else:                               # else is currently on...
            power('off', 1.15, True)        # Power down
            mode = 0                        # OFF mode now
            enable.value = False
        while not switch.value:             # Wait for button release
            time.sleep(0.2)                 # to avoid repeated triggering
