Peristaltic pump in reverse
lame_sauce
Post by lame_sauce »
Hi All,
I'm working on a project and could use some help. I was wondering how I could run a peristaltic pump in reverse using circuit python. I have the pump turning on through a non latching relay attached to a FunHouse (code below). Any tips would be great!
import board
import time
import digitalio
water_pump = digitalio.DigitalInOut(board.A2)
water_pump.direction = digitalio.Direction.OUTPUT
water_pump.value = True
time.sleep(5)
water_pump.value = False
Re: Peristaltic pump in reverse
You can't do it with a single relay. To reverse a motor you need an 'H-Bridge' like the one on a TB6612B: https://learn.adafruit.com/adafruit-tb6 ... r-breakout
lame_sauce
adafruit_support_bill wrote:You can't do it with a relay. To reverse a motor you need an 'H-Bridge' like the one on a TB6612B: https://learn.adafruit.com/adafruit-tb6 ... r-breakout
Oh thank you I'll check this out!
Also check the current requirements of your motor. If it pulls more than 1.2A, you will need something with more current capacity like the DRV8871: https://www.adafruit.com/product/3190
jps2000
Post by jps2000 »
Of course you can use 2 relays wired like a h bridge
( single pole double throw relay contact)
