I am working a project for haptic feedback. I found below tutorial, Haptic Headband.
https://learn.adafruit.com/haptic-headband?view=all
Can I connect two 'Vibrating Mini Motor Disc' to a 'DRV2605L Haptic Motor Controller'? Will this setup lose vibration power by divining into two motor discs?
Can I connect multiple vibrating mini motor disc to a haptic
- dofl1234
- dastels
Re: Can I connect multiple vibrating mini motor disc to a ha
I have no doubt that connecting more than one ERM or LRA will mess up the "smart-loop architecture" that's based on back-emf from the motor. I advise against it.
- Franklin97355
It will probably work, it will depend on what you mean by "lose power". It will but you might not feel the difference.
- dofl1234
Thanks for the quick answer. I got two different answers so what's right answer?
- dastels
The thing is, it's not just a motor driver that controls current going through the motor to make it spin (or oscillate in the case of a LRA). It uses back-emf generated by the motor to precisely control it. Having two motors connected will muddy that (since they are almost guaranteed to be out of sync ... they aren't just spinning shafts, they have an offset weight that effects the motions as well as creating the vibration) and degrade the result, likely significantly. As I said, it's a much more comples chip/system that just turning a motor on & off.
- dofl1234
Thank Dastels for your answer. I just wand to control On/Off two motors together simply by setting pause in between On/Off. Will this work then?
- dastels
You don't need a haptic controller for that. You can use a DRV8833 breakout https://learn.adafruit.com/adafruit-drv ... kout-board that will let you control the two motors individually: turning them on/off or PWMing them.
- dofl1234
Hey Dave,
I thought the haptic controller would be simplest solution to control the vibrating mini motor disc by following the tutorial. I am planning a wearable project so want to keep everything simple. For this reason, I am thinking of using GEMMA v2 as micro controller. I am not sure DRV8833 breakout work with GEMMA v2 because of lack of power/pins.
Dofl
Dofl
- dastels
Fair point. But, since you are using the tiny pan motors (and not, e.g., hefty motors to drive a robot) and just need to turn them on/off you can probably get away with a simple transistor control circuit. See https://learn.adafruit.com/adafruit-ard ... -dc-motors.
- dofl1234
I found same solution from below project originally but it looks a bit complex again using the haptic controller. I wanted to try to figure out with simpler option but you said it would not work.
https://learn.adafruit.com/buzzing-mind ... t?view=all
Any way to use two haptic controllers then? Otherwise I would go with the classic way.
Many thanks,
Dofl
Many thanks,
Dofl
- dastels
Since the haptic controller doesn't have an adjustable I2C address, you would need to use an I2C multiplexer https://www.adafruit.com/product/2717.
- dofl1234
It looks the classical way would be the simplest option so far. I am not good at wiring so can I simply duplicate the wiring setup like the image I attached?
Dave, you saved my life.
- disc.jpg (147 KiB) Viewed 261 times
- dofl1234
Or can I just wire like this simply because I just control both discs at the same time.
- disc-2.jpg (132.74 KiB) Viewed 261 times
- dastels
That looks right. pay attention to which pins on the transistor are what.
- dofl1234
It's so great to figure out simplest way to play two vibration discs by connecting to one control component. I'll order all components tomorrow morning and will follow your instruction.
Thanks a lot, Dave.
Thanks a lot, Dave.
