LCD Partial Row Display
by quasilister on Sun Dec 05, 2010 1:20 pm
I am following ladyada's tutorial (http://www.ladyada.net/learn/lcd/charlcd.html) to get an LCD working with an arduino and I think I may have a defective LCD screen. I have attached an image which shows just part of the screen working. Ladyada says that the bottom row should be filled. Mine, however, displays only 8, and those are partially filled. Any suggestions?
quasilister
Re: LCD Partial Row Display
by franklin97355 on Sun Dec 05, 2010 2:24 pm
Looking at the tutorial it is the top row that should be lit. if all your wiring is correct you may have a bad display, check your wiring carefully. (there isn't much but check anyway)
franklin97355
by stinkbutt on Sun Dec 05, 2010 3:58 pm
Can you post high-res images of your soldering of the header pins, top and bottom?
Red M&M, Blue M&M: They all wind up the same color
stinkbutt
by zener on Sun Dec 05, 2010 9:38 pm
That display looks pretty bad. Where did you get it? I never saw one look quite like that. Have you tried turning it off and on again?
zener
