Components in this system are a 6600mAh lipo battery, lipo charging board Adafruit #4410, a motor speed control board, and a 6v Pump
We are working on a prototype for our live bait aerator pump system and recently purchased product 4410, however it doesn't appear strong enough to power this motor speed control board #1 (see board 1 link below)
Does this make sense? I've connected everything correctly but the speed control board #1 will not turn on. The system works using this board #2 (see board 2 link below)
I think I might have to use the 1903 or 1944 to get enough power to it. Can you please advise if this is correct? Also advise, if you have a version of 1903 or 1944 with USB C.
Components:
Speed control board 1: https://tinyurl.com/ykt7hsed
Speed control board 2: https://tinyurl.com/59rsxv7a
Pump: https://tinyurl.com/3ynfz7dz
Help with selecting Lipo Charge Board
- dastels
Re: Help with selecting Lipo Charge Board
I'm a little confused. How does a LiPo charger (4410) fit in into your design?
There are currently no LiPo chargers with USB-C connectors. [edit] other than the 4410... but none of the PowerBoosts.
- keepr
Hi Dave, thanks for the response. Here is a picture of the setup: https://imgur.com/a/2FfKJDZ?s=sms
I think I figured it out - the #1 PWM board is rated for 6v.
- dastels
Yes, it looks like the controllers and motors you linked to are 6v (or more for the controllers)
Where does the battery fit in? To power the motor/controller? You are right that it's not high enough voltage for that (topping out at 4.2 with a full charge). One of the PowerBoosts will give you ~5.2v from a LiPo, but that's still shy of the 6v you need.
