the original project calls for 2m led strip, i only have a meter which has 144 leds.
when i use the original code a bunch of leds on the end of the strip dont light up i get the first 14 show as orange the next lot show blue and then some more on the end show as orange and a bunch of strips are on the end dont light up at all.
i modified the code so that the first 21 show up as orange and the rest as blue but again it wont activate a bunch of leds at the end of the strip.
any suggestion. i have included the original code below. would also be great to reduce the time delay from sliding the switch to the leds lighting up.
// SPDX-FileCopyrightText: 2018 Mikey Sklar for Adafruit Industries
// SPDX-License-Identifier: MIT
#ifdef __AVR__
#include <avr/power.h>
#endif
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1
#define PIN 4
// Color Segments
#define APIXELS 14 // number of first orange pixels
#define BPIXELS 84 // number of blue pixels
#define CPIXELS 93 // second orange pixels
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values.
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(93, PIN, NEO_GRB + NEO_KHZ800);
int delayval = 10; // delay for half a second
// This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
#if defined (__AVR_ATtiny85__)
if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
#endif
// End of trinket special code
pixels.begin(); // This initializes the NeoPixel library.
// For the first 14 pixels, make them orange, starting from pixel number 0.
for(int i=0;i<APIXELS;i++){
pixels.setPixelColor(i, pixels.Color(255,50,0)); // Set Pixels to Orange Color
pixels.show(); // This sends the updated pixel color to the hardware.
delay(delayval); // Delay for a period of time (in milliseconds).
// Fill up 84 pixels with blue, starting with pixel number 14.
for(int i=14;i<BPIXELS;i++){
pixels.setPixelColor(i, pixels.Color(0,250,200)); // Set Pixels to Blue Color
// Fill up 9 pixels with orange, starting from pixel number 84.
for(int i=84;i<CPIXELS;i++){
pixels.setPixelColor(i, pixels.Color(250,50,0)); //Set Pixels to Orange Color
