Neopixel LED strip modified code from zelda sword project
dre_force
Post by dre_force »
trying to modify some code for the zelda sword project to suit the led strip i have.
the original project calls for 2m led strip, i only have a meter which has 144 leds.
when i use the original code a bunch of leds on the end of the strip dont light up i get the first 14 show as orange the next lot show blue and then some more on the end show as orange and a bunch of strips are on the end dont light up at all.
i modified the code so that the first 21 show up as orange and the rest as blue but again it wont activate a bunch of leds at the end of the strip.
any suggestion. i have included the original code below. would also be great to reduce the time delay from sliding the switch to the leds lighting up.
// SPDX-FileCopyrightText: 2018 Mikey Sklar for Adafruit Industries
// SPDX-License-Identifier: MIT
#ifdef __AVR__
  #include <avr/power.h>
#endif
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1
#define PIN            4
// Color Segments
#define APIXELS      14 // number of first orange pixels
#define BPIXELS      84 // number of blue pixels
#define CPIXELS      93 // second orange pixels
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values.
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(93, PIN, NEO_GRB + NEO_KHZ800);
int delayval = 10; // delay for half a second
  // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
#if defined (__AVR_ATtiny85__)
  if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
#endif
  // End of trinket special code
  pixels.begin(); // This initializes the NeoPixel library.
  // For the first 14 pixels, make them orange, starting from pixel number 0.
  for(int i=0;i<APIXELS;i++){
    pixels.setPixelColor(i, pixels.Color(255,50,0)); // Set Pixels to Orange Color
    pixels.show(); // This sends the updated pixel color to the hardware.
    delay(delayval); // Delay for a period of time (in milliseconds).
  // Fill up 84 pixels with blue, starting with pixel number 14.
  for(int i=14;i<BPIXELS;i++){
    pixels.setPixelColor(i, pixels.Color(0,250,200)); // Set Pixels to Blue Color
  // Fill up 9 pixels with orange, starting from pixel number 84.
  for(int i=84;i<CPIXELS;i++){
    pixels.setPixelColor(i, pixels.Color(250,50,0)); //Set Pixels to Orange Color
Last edited by adafruit_support_carter on Mon Oct 18, 2021 1:24 pm, edited 1 time in total.
Reason: added [code] tags
dastels
Re: Neopixel LED strip modified code from zelda sword projec
Post by dastels »
To use all 144 pixels you need to instantiate the NeoPixel object for 144 pixels.
is instantiating it for 93 pixels. It is ignoring any beyond that number. Change that 93 to 144 to have it use all the pixels.
dre_force
Post by dre_force »
Thanks for the reply Dave, Ive posted below the modified code i tried before posting this as you can see i tried changing this number but when i did this nothing happened as in no leds lit up at all. i will try again but am quite sure i tried it multiple times the other day.
modified code -
#ifdef __AVR__
#endif
#define PIN            4
// Color Segments
#define APIXELS      21 // number of first orange pixels
#define BPIXELS      110 // number of blue pixels
#define CPIXELS      13 // second orange pixels
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(144, PIN, NEO_GRB + NEO_KHZ800);
#endif
  // For the first 21 pixels, make them orange, starting from pixel number 0.
  // Fill up 110 pixels with blue, starting with pixel number 21.
  for(int i=21;i<BPIXELS;i++){
  // Fill up 13 pixels with orange, starting from pixel number 131.
  for(int i=131;i<CPIXELS;i++){
dastels
Post by dastels »
One problem I see is in your for loops. Here;s the orage (I believe the same problem is in the blue one):
I believe the limit should be 131 + CPIXELS As CPIXELS, BPIXELS, etc are the number of pixels, not the index of the last one in the group.
dre_force
Post by dre_force »
Appreciate the response Dave, not having much luck. When i change the 93 number to anything 144 no LEDs light up. Even if i remove the B and C pixels and just try and fill the strip with the one colour. ive recharged the battery and will try again as i was getting some random results from the low battery. blue was turning green and such. also if you could clarify what you mean by the your statement "i belive the limit should be 131 + CPIXELS ... etc are the number of pixels, not the index of the last one in the group."
Also ive noted in the code it says - :Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values."
do you know what this ment by this.
who would have thought getting leds to light up would be so hard.
Thanks again.
dre_force
Post by dre_force »
results of original code
dastels
Post by dastels »
The original code specifies 93 pixels so it will never light up more than that.
The APIXELS, BPIXELS, and CPIXELS in the original code are the index of the last pixel in each group. In your code they are the number of pixels in each ground. For example, your second orang loop is equivalent to
for (int i = 131; i < 13; i++)
So the loop never loops because i starts out greater than 13.
Since the original code worked, the erd argument to the NeoPixel constructor is correct. Some NeoPixels have R, G, and B is a different order. and expect a control signal a different frequency. That's hat the 3rd argument is for.
I find it useful to have the circuit attached to USB for power when working on the code. That will eliminate battery issues as a source of problems. Once you know everything works, then you can deal with battery powering it.
dre_force
Post by dre_force »
#ifdef __AVR__
#endif
#define PIN            4
// Color Segments
#endif
  for(int i=110;i<BPIXELS;i++){
  for(int i=13;i<CPIXELS;i++){
Last edited by adafruit_support_carter on Mon Oct 18, 2021 1:23 pm, edited 1 time in total.
dre_force
Post by dre_force »
this is the error message i get when loading this modified code
Screen Shot 2021-10-18 at 1.01.10 pm.png (151.13 KiB) Viewed 191 times
dastels
Post by dastels »
I've never seen that one. I'll see what I can find out.
adafruit2
Post by adafruit2 »
what board are you using? a trinket 5V?
dre_force
Post by dre_force »
yes trinket 5v
dre_force
Post by dre_force »
#ifdef __AVR__
#endif
#define PIN 4
// Color Segments
#endif
dre_force
Post by dre_force »
Managed to load the code above with no error message but when i test no leds light up at all.
dastels
Post by dastels »
First, consider upgrading to a Trinket M0. The older Trinket models are known to have problems with more modern USB implementations. There's a warning to that effect on the product page.
Secondly, your for loops are still incorrect. Please reread my previous responses regarding the code.
