I ordered a Rockblock 9603 from Adafruit a few months ago, and I am just getting around to using it because I had to get radio frequency permission to use for a Navy research project first (which I now have).
I've used Rockblocks in the past while I was in college and never had an issue with them. However I can't get the simple hello world tutorial from your website to work with this particular Rockblock. I've tried send short burst data in 3 different locations dozens of times and have been unsuccessful each time.
I have line rental and plenty of credits so this seems to be an issue with the device itself or possibly the antenna. The antenna also looks dirty (or possible burned?) I have attached a photo.
Rockblock 9603 can't send SBD
- tkschuler
- IMG_5882.jpg (136.71 KiB) Viewed 138 times
- mikeysklar
Re: Rockblock 9603 can't send SBD
This will be a more complicated issue than usual for a replacement as you are outside our 30-day warranty, but we can try and work with you.
Can you do a basic COMMS check using the AT commands and screen?
https://learn.adafruit.com/using-the-ro ... -3058797-6
+SBDIX - Initiate an Short Burst Data session, i.e. talk to the satellites. Make sure you have loaded message data first.
+SBDWT - Write text message into outbound buffer
+SBDWB - Write binary data into outbound buffer
+SBDRT - Read text message from inbound buffer
+SBDRB - Read binary data in from inbound buffer
+SBDSX - Status
- tkschuler
I have attached an image of the responses from the Rock Block.
- rockblock_error.png (28.88 KiB) Viewed 118 times
- adafruit2
for this kind of detailed question please email rockblock - the hardware seems OK (its communicating) so it could be a service or setup issue which we don't have any access to!
