Hi all,
I am making a Pi NoIR wildlife camera, and I would like to have PIR modules remote from the camera body, one near each side of the camera's field of view, or wherever they seem most likely to detect small critters. I want to use standard phone jacks and cables to connect the PIR remote units to the main. I need RJ14-F connectors that can be mounted flush in plexiglas case material 1/8" thick or so. This shop only carries one RJ12 connector, but not one that would fit my needs. DigiKey sells about 200 different RJ14 connectors, but it is difficult to determine if they would work from the descriptions. MicroCenter sells things you screw into your wall.
Thanks,
Scott
Need suggestions for RJ14-F connector
- mikeysklar
Re: Need suggestions for RJ14-F connector
Scott,
If you are willing to use RJ-45 we have some options for you
https://www.adafruit.com/?q=rj45&sort=BestMatch
