MCP23017 library issue
derianlebreton
Post by derianlebreton »
Hi all,
I'm having a weird problem with the Adafruit_MCP23X17 library (I have the latest installed, and latest version of BusIO), specifically when trying to set up one of these devices with a defined I2C address. For testing purposes, I have reduced my system to the following:
1x QTPY microcontroller, providing 3.3V and GND
1x mcp23017 at I2C address 0x00 (pins A0, A1, A2 connected to GND)
mcp 23017 ~reset line pulled to 3.3V via 100kΩ
0.1 uF and 10uF caps on 3.3V
2.2kΩ pull-ups to 3.3V on SCK and SCL pins from QTPY
Plus a couple of wires to pull some of the mcp23017 IO pins high so I can make sure I'm really reading them
When I run the following sketch, this device works as anticipated:
#include <Adafruit_MCP23X17.h>
// Create IO expander instance
Adafruit_MCP23X17 mcp0;
    mcp0.begin_I2C();
    Serial.begin(9600);
    Serial.println("Reading mcp0 port: " + String(mcp0.readGPIO()));
    delay(1000);
I get output like this:
Reading mcp0 port: 32
Which corresponds to the one wire I have pulling a pin high. However, this is not suitable for me as I need multiple mcp23017s on the I2C bus for my project. If I try to provide an I2C address in mcp0.begin_I2C(), I only get bogus data:
    mcp0.begin_I2C(0);
    Serial.begin(9600);
    delay(1000);
Reading mcp0 port: 255
I have tried 0x00, (uint8_t)0, and 0, but they all show the same broken behavior.
derianlebreton
Re: MCP23017 library issue
I reverted the library to version 1.3, and now the following code works:
#include <Adafruit_MCP23017.h>
Adafruit_MCP23017 mcp0;
    mcp0.begin((uint8_t)0);
    Serial.begin(9600);
    Serial.println("Reading mcp0 port: " + String(mcp0.readGPIO(0)));
    delay(1000);
adafruit_support_carter
That won't actually set 0 for an address. Try configuring A0/A1/A2 like you want, and then see what address shows up in an I2C scan:
https://learn.adafruit.com/scanning-i2c ... es/arduino
For reference, A0/A1/A2 are setting 3 bits of the address. The other bits are fixed (and non-zero):
derianlebreton
Interesting. Using version 1.3 of the library I have two MCP23017s communicating properly, one at 0x00 and one at 0x01. Maybe the old library does some magic that the new version undid and didn't document?
Oh, there was a change. OK, sorry about that. There were breaking changes introduced at the 2.0.0 release:
https://github.com/adafruit/Adafruit-MC ... /tag/2.0.0
Prior to that, the "address" was essentially only a 3bit value representing A0/A1/A2:
https://github.com/adafruit/Adafruit-MC ... #L118-L122
The fixed upper bits were or'd in at write time:
https://github.com/adafruit/Adafruit-MC ... 17.cpp#L73
Now the address is the full address - same as you'd see when running an I2C scan.
derianlebreton
Thanks for the note. It would be useful if this change was reflected in the example sketches.
Brian.
