ESP32 Feather WS2811 Control
bcs5399
Post by bcs5399 »
We are trying to use an ESP32 Feather to control a WS2811 ARGB light strip. We are also using a Sparkfun BOB-11771 Voltage Level Translator that uses a Texas Instruments TXB0104. We are getting all of the LEDs turning white with no control over how many LEDs turn on. We are using the example codes from the FastLED library. The signal line is attached to DAC2/A0 and then sent to channel 1 of the logic level shifter.
#include <FastLED.h>
FASTLED_USING_NAMESPACE
// FastLED "100-lines-of-code" demo reel, showing just a few
// of the kinds of animation patterns you can quickly and easily
// compose using FastLED.
// This example also shows one easy way to define multiple
// animations patterns and have them automatically rotate.
// -Mark Kriegsman, December 2014
#if defined(FASTLED_VERSION) && (FASTLED_VERSION < 3001000)
#warning "Requires FastLED 3.1 or later; check github for latest code."
#endif
#define DATA_PIN    DAC2
//#define CLK_PIN   4
#define LED_TYPE    WS2811
#define COLOR_ORDER BRG
#define NUM_LEDS    6
CRGB leds[NUM_LEDS];
#define BRIGHTNESS          96
#define FRAMES_PER_SECOND  120
  delay(3000); // 3 second delay for recovery
  // tell FastLED about the LED strip configuration
  FastLED.addLeds<LED_TYPE,DATA_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
  //FastLED.addLeds<LED_TYPE,DATA_PIN,CLK_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
  // set master brightness control
  FastLED.setBrightness(BRIGHTNESS);
// List of patterns to cycle through.  Each is defined as a separate function below.
typedef void (*SimplePatternList[])();
SimplePatternList gPatterns = { rainbow, rainbowWithGlitter, confetti, sinelon, juggle, bpm };
uint8_t gCurrentPatternNumber = 0; // Index number of which pattern is current
uint8_t gHue = 0; // rotating "base color" used by many of the patterns
void loop()
  // Call the current pattern function once, updating the 'leds' array
  gPatterns[gCurrentPatternNumber]();
  // send the 'leds' array out to the actual LED strip
  FastLED.show();
  // insert a delay to keep the framerate modest
  FastLED.delay(1000/FRAMES_PER_SECOND);
  // do some periodic updates
  EVERY_N_MILLISECONDS( 20 ) { gHue++; } // slowly cycle the "base color" through the rainbow
  EVERY_N_SECONDS( 10 ) { nextPattern(); } // change patterns periodically
#define ARRAY_SIZE(A) (sizeof(A) / sizeof((A)[0]))
void nextPattern()
  // add one to the current pattern number, and wrap around at the end
  gCurrentPatternNumber = (gCurrentPatternNumber + 1) % ARRAY_SIZE( gPatterns);
void rainbow()
  // FastLED's built-in rainbow generator
  fill_rainbow( leds, NUM_LEDS, gHue, 7);
void rainbowWithGlitter()
  // built-in FastLED rainbow, plus some random sparkly glitter
  rainbow();
  addGlitter(80);
void addGlitter( fract8 chanceOfGlitter)
  if( random8() < chanceOfGlitter) {
    leds[ random16(NUM_LEDS) ] += CRGB::White;
void confetti()
  // random colored speckles that blink in and fade smoothly
  fadeToBlackBy( leds, NUM_LEDS, 10);
  int pos = random16(NUM_LEDS);
  leds[pos] += CHSV( gHue + random8(64), 200, 255);
void sinelon()
  // a colored dot sweeping back and forth, with fading trails
  fadeToBlackBy( leds, NUM_LEDS, 20);
  int pos = beatsin16( 13, 0, NUM_LEDS-1 );
  leds[pos] += CHSV( gHue, 255, 192);
void bpm()
  // colored stripes pulsing at a defined Beats-Per-Minute (BPM)
  uint8_t BeatsPerMinute = 62;
  CRGBPalette16 palette = PartyColors_p;
  uint8_t beat = beatsin8( BeatsPerMinute, 64, 255);
  for( int i = 0; i < NUM_LEDS; i++) { //9948
    leds[i] = ColorFromPalette(palette, gHue+(i*2), beat-gHue+(i*10));
void juggle() {
  // eight colored dots, weaving in and out of sync with each other
  byte dothue = 0;
  for( int i = 0; i < 8; i++) {
    leds[beatsin16( i+7, 0, NUM_LEDS-1 )] |= CHSV(dothue, 200, 255);
    dothue += 32;
adafruit_support_mike
Re: ESP32 Feather WS2811 Control
The TXB0104 may not be strong enough to drive the wiring.
That chip is intended to sit between ICs on a circuit board and support two-way communication. To make that work, it provides a weak output signal by default (so it can sense input from the connected device) then boosts the signal strength shortly after seeing a signal change from the device on the other side. We’ve had reports in the past from people who had problems when trying to use it with devices that wanted a stronger signal.
All wire has a certain amount of parasitic capacitance, and even a few inches of wiring can distort a TXB0104’s output enough that NeoPixels signals become useless.
We suggest using a regular logic buffer like the 74AHCT125 as a level shifter for NeoPixel signals. It’s more than fast enough, and provides good strong signals:
https://www.adafruit.com/product/1787
