ADS1115 with OLED Display - Only A0 operational
- CPW
Working a project where I'd like to display several channels from the ads1115 on a small OLED display. All 4 channels of the ads1115 work as expected in isolation. However, when I add an OLED display to the I2C bus, only the A0 channel of the ads1115 is operational. Channels A1, shows a value of unknown origin...about 1.9 V, and A2, A2 show 0. The ads1115 is at 0x48; the OLED is at 0x3C, as detected by the device scanner. I've changed the OLED to 0x3D...same result. Any thoughts?
Re: ADS1115 with OLED Display - Only A0 operational
What is connected to those channels?
- CPW
Testing with 4.5 volt DC source.
Please post your code and a photo of your setup. That might provide some clues.
- CPW
[img]
[/img] [attachment=0]A2D-OLEDSetup.jpg. Photo with 4.5 v DC source to each A2D input with OLED display of result, one of the whole setup using Arduino UNO and the code the UNO is running..Code: Select all
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_ADS1X15.h>
Adafruit_ADS1115 ads;
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
#define OLED_RESET 4 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3D
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
Serial.begin(9600);
if (!ads.begin()) {
Serial.println("Failed to initialize ADS.");
while (1);
ads.setGain(GAIN_TWOTHIRDS);
if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
display.clearDisplay();
display.setTextColor(SSD1306_WHITE); // Draw white text
display.cp437(true); // Use full 256 char 'Code Page 437' font
display.setTextSize(1);
int16_t adc3, adc1, adc2, adc0;
float volts3, volts1, volts2, volts0;
float sum1, sum2, sum3, sum0;
const int n = 1;
sum0 = sum1 = sum2 = sum3 = 0.0;
for (int i = 1; i <= n; i++){
adc0 = ads.readADC_SingleEnded(0);
adc1 = ads.readADC_SingleEnded(1);
adc2 = ads.readADC_SingleEnded(2);
adc3 = ads.readADC_SingleEnded(3);
sum0 = sum0 + float(adc0);
sum1 = sum1 + float(adc1);
sum0 = sum0/float(n);
sum1 = sum1/float(n);
sum2 = sum2/float(n);
sum3 = sum3/float(n);
volts0 = ads.computeVolts(sum0);
volts1 = ads.computeVolts(sum1);
volts2 = ads.computeVolts(sum2);
volts3 = ads.computeVolts(sum3);
Serial.println("V0 = " + String(volts0,4));
Serial.println("V1 = " + String(volts1,4));
Serial.println("V2 = " + String(volts2,4));
Serial.println("V3 = " + String(volts3,4));
display.setCursor(0,0);
display.println("v0 = " + String(volts0,4));
display.setCursor(0,8);
display.println("v1 = " + String(volts1,4));
display.setCursor(0,16);
display.println("v2 = " + String(volts2,4));
display.setCursor(0,24);
display.println("v3 = " + String(volts3,4));
display.display();
delay(1000);
- A2D-OLEDSetup.jpg (383.45 KiB) Viewed 158 times
- CPW
I found the problem...opied code and didn't review it closely enough.
You only have a connection to A0. All the others are floating. Their values are 'undefined'.
