Module not found error
Jmiramo22
Post by Jmiramo22 »
I am trying to get this python code to run on Beaglebone Black, the code is trying to get the temperature from a sensor and display it on a 7-segment LED backpack, here is the code:
import Adafruit_BBIO.ADC
import time
import datetime
from Adafruit_7Segment import SevenSegment
segment = SevenSegment(address=0x70)
sensor_pin = 'P9_40'
ADC.Setup()
While(True);
reading = ADC.read(sensor_pin)
millivolts = reading * 1800
temp_c = (millivolts - 500) / 10
segment.WriteDigit(0,int(temp_c / 10))
segment.WriteDigit(1,int(temp_c % 10))
segment.WriteDigit(3,12)
segment.setColon(1)
time.sleep(1)
// I am getting an error saying that "Adafruit_7Segment" module doesn't exist.
Screenshot 2021-12-01 131157.png (78.16 KiB) Viewed 129 times
dastels
Re: Module not found error
Post by dastels »
Are you using Blinka and have installed the SevenSegment library? For something similar see https://learn.adafruit.com/circuitpytho ... rypi-linux.
