Bluetooth Shield Project
RXB974
Post by RXB974 »
I'm currently using the Adafruit Bluefruit LE Shield on Arduino Mega2560. They are both connected via stacked headers.
To test the product, I have used the example "atcommand" code.
I have altered the SPI pins accordingly (pins 50-52 for MISO, MOSI and SCK respectively).
Still, every time I'm trying to run the code, it cannot do a factory reset.
When trying, the serial monitor creates a string "⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮". It's repeated every couple of seconds for at least a minute.
The shield itself blinks red near the MODE led, if that helps.
I have no clue what am I doing wrong, any help would be welcome!
adafruit_support_mike
Re: Bluetooth Shield Project
RXB974 wrote:When trying, the serial monitor creates a string "⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮". It's repeated every couple of seconds for at least a minute.
That looks like a Serial baudrate mismatch.
As a sanity check, make sure your Serial Monitor matches the baudrate in your code.
