SI4713 FM Transmitter
- w0ivj
I am using the Adafruit si4713 library with the provided example on a Nano Every. The transmitter only works if the serial monitor window is open on the Arduino 1.8.13 IDE.
Re: SI4713 FM Transmitter
Check your code to see if it has something like this at the top of setup():
That's fairly common for microcontrollers that handle USB internally, but hangs when there's no USB connection.
while ( ! Serial ) { delay( 1 ); }
- w0ivj
Thanks...I solved the problem with an external reset button that I use after the power is applied.
