I have the raspberry pi and I play around with the raspberrypi tank from adeept.
Here is the official github link
https://github.com/adeept/adeept_raspta ... ts-program
When I want to start the server with
sudo python3 adeept_rasptank/server/webServer.py
I get this error
File "/usr/local/lib/python3.9/dist-packages/Adafruit_GPIO/I2C.py", line 55, in get_default_bus
raise RuntimeError('Could not determine default I2C bus for platform.')
RuntimeError: Could not determine default I2C bus for platform.
I have enabled i2c interface
with i2cdetect -l i get this
pi@raspberrypi:~/adeept_rasptank/server $ i2cdetect -l
i2c-1 i2c bcm2835 (i2c@7e804000) I2C adapter
- strammerJunge
- strammerJunge
Re: RuntimeError: Could not determine default I2C bus for pl
does anyone have a fix for that?
- adafruit_support_carter
The project appears to be using a deprecated library:
https://github.com/adafruit/Adafruit_Python_GPIO
- strammerJunge
ok well, what do I need to do to fix it?
is there an updated library out there yet?
The project would need to be updated to use Blinka:
https://learn.adafruit.com/circuitpytho ... spberry-pi
That would provide basic GPIO functionality. For any external devices (like I2C or SPI sensors), the associated CircuitPython library would be used.
- CCM
Hi. So, I updated my CircuitPython using the shared link. I did the I2C test, and this was the result I got:
pi@pi:~ $ ls /dev/i2c* /dev/spi*
/dev/i2c-0 /dev/i2c-10 /dev/i2c-21 /dev/spidev0.0
/dev/i2c-1 /dev/i2c-20 /dev/i2c-22 /dev/spidev0.1
Does this mean I have 6 available and need to specify the default?
- OSP123
Hi there,
I'm also interested in resolving this issue. I purchased the Adeept PiCar Pro a few days back and the software seems really out of date. I had to go to forums to get the latest information to update everything. I'm using Blinka now and I have 6 I2C as the poster above mentioned, but I'm still getting the error mentioned as well. Is there an update for this to resolve the issue? I'm currently trying to run in order to make the PiCar Pro activate.
sudo python3 adeept_picarpro/server/webServer.py
Please contact the maintainers of the Adeept PiCar Pro project.
- strammerJunge
who are they?adafruit_support_carter wrote:Please contact the maintainers of the Adeept PiCar Pro project.
do you have a lik or something?
- OSP123
Oh yeah, that was very stupid of me. For some reason, I thought the software was being maintained by you guys. Sorry about that! Yeah, it's from Adeept. Sigh, I should know better.
