Can't get 16x16 Matrix to work fully?
- keithschaub
Am I doing something wrong, or it fundamentally doesn't support 16x16.
(The matrix is ALL ONE PIECE). I ordered it from BTF-Lighting. Here's the link to it if needed.
[url]]https://www.amazon.com/BTF-LIGHTING-0-4 ... 8461&psc=1[/url
// Adafruit_NeoMatrix example for single NeoPixel Shield.
// Scrolls 'Howdy' across the matrix in a portrait (vertical) orientation.
#include <Adafruit_GFX.h>
#include <Adafruit_NeoMatrix.h>
#ifndef PSTR
#define PSTR // Make Arduino Due happy
#endif
#define PIN 6
// MATRIX DECLARATION:
// Parameter 1 = width of NeoPixel matrix
// Parameter 2 = height of matrix
// Parameter 3 = pin number (most are valid)
// Parameter 4 = matrix layout flags, add together as needed:
// NEO_MATRIX_TOP, NEO_MATRIX_BOTTOM, NEO_MATRIX_LEFT, NEO_MATRIX_RIGHT:
// Position of the FIRST LED in the matrix; pick two, e.g.
// NEO_MATRIX_TOP + NEO_MATRIX_LEFT for the top-left corner.
// NEO_MATRIX_ROWS, NEO_MATRIX_COLUMNS: LEDs are arranged in horizontal
// rows or in vertical columns, respectively; pick one or the other.
// NEO_MATRIX_PROGRESSIVE, NEO_MATRIX_ZIGZAG: all rows/columns proceed
// in the same order, or alternate lines reverse direction; pick one.
// See example below for these values in action.
// Parameter 5 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_GRBW Pixels are wired for GRBW bitstream (RGB+W NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
// Example for NeoPixel Shield. In this application we'd like to use it
// as a 5x8 tall matrix, with the USB port positioned at the top of the
// Arduino. When held that way, the first pixel is at the top right, and
// lines are arranged in columns, progressive order. The shield uses
// 800 KHz (v2) pixels that expect GRB color data.
//Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(7, 8, PIN,
// NEO_MATRIX_TOP + NEO_MATRIX_LEFT +
// NEO_MATRIX_ROWS + NEO_MATRIX_ZIGZAG,
// NEO_GRB + NEO_KHZ800);
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(16,16, PIN,
NEO_MATRIX_COLUMNS + NEO_MATRIX_ZIGZAG,
const uint16_t colors[] = {
matrix.Color(255, 0, 0), matrix.Color(0, 255, 0), matrix.Color(0, 0, 255) };
matrix.begin();
matrix.setTextWrap(false);
matrix.setBrightness(40);
matrix.setTextColor(colors[0]);
int x = matrix.width();
int pass = 0;
matrix.fillScreen(0);
matrix.setCursor(x, 0);
//matrix.print(F("If you can read this, please answer the question: are you male?"));
//matrix.print(F("IIIIII"));
matrix.print(F("HELLO"));
if(--x < -120) {
x = matrix.width();
if(++pass >= 3) pass = 0;
matrix.setTextColor(colors[pass]);
//matrix.setTextColor(colors[2]);
matrix.show();
delay(100);
- keithschaub
Re: Can't get 16x16 Matrix to work fully?
Also, just to make sure there's nothing wrong with the h/w...Here's a photo of a 16x16 that I could upload and display properly.
#ifndef PSTR
#endif
#define PIN 6
const unsigned short ironMan16x16[240] PROGMEM={
0xF7BE, 0xF7BE, 0xF7BE, 0xF7BE, 0xF7BE, 0xF7BE, 0xAD55, 0x6B4D, 0x6B4D, 0x6B4D, 0xA534, 0xF7BE, 0xF7BE, 0xF79E, 0xF7BE, 0xF7BE, // 0x0010 (16) pixels
0xF7BE, 0xF7BE, 0xFFFF, 0xFFFF, 0x84B2, 0x2A8A, 0x61C7, 0x8924, 0x8945, 0x8924, 0x61C7, 0x2AAA, 0x84B2, 0xFFFF, 0xFFDF, 0xF7BE, // 0x0020 (32) pixels
0xF7BE, 0xFFFF, 0xFFFF, 0x7CB2, 0x6125, 0x80C4, 0xD9A7, 0xFA49, 0xFA8A, 0xFA6A, 0xE146, 0x8000, 0x68A3, 0x7CD3, 0xFFFF, 0xF7BE, // 0x0030 (48) pixels
0xF7BE, 0xFFFF, 0x7430, 0x6925, 0xE9CA, 0xFD0C, 0xFB68, 0xF8E6, 0xF966, 0xF0C5, 0xF2C6, 0xFC28, 0xE044, 0x4842, 0x7451, 0xF7BE, // 0x0040 (64) pixels
0xF7BE, 0xFFFF, 0x0925, 0x98C6, 0xFCAC, 0xFF26, 0xFE04, 0xFA66, 0xE846, 0xD246, 0xEE66, 0xFEE5, 0xFB05, 0x7000, 0x0966, 0xF7BE, // 0x0050 (80) pixels
0xF7BE, 0x7430, 0x7106, 0xEC48, 0xFF07, 0xFF23, 0xFF43, 0xFE04, 0xFC64, 0xFE04, 0xFFA5, 0xFF43, 0xFE43, 0xC242, 0x4843, 0x8C71, // 0x0060 (96) pixels
0xF7BE, 0x00A2, 0xB8E7, 0xFE8A, 0xFF84, 0x8322, 0x18C1, 0xA423, 0xFF24, 0xA443, 0x18C1, 0x8343, 0xFEE3, 0xEC22, 0x7800, 0x4A49, // 0x0070 (112) pixels
0xF7BE, 0x00E3, 0xB927, 0xFEAA, 0xFF84, 0xB463, 0x72E2, 0xCCE3, 0xFEC4, 0xCD03, 0x72E2, 0xBCA4, 0xFF03, 0xEC42, 0x7801, 0x4A49, // 0x0080 (128) pixels
0xF7BE, 0x00A2, 0xB947, 0xFB6A, 0xFE26, 0xFF24, 0xFEC4, 0xFEA4, 0xFE84, 0xFEA4, 0xFEE4, 0xFEA3, 0xF4E3, 0xD9C3, 0x8000, 0x4A49, // 0x0090 (144) pixels
0xF7BE, 0x9514, 0x4966, 0xD025, 0xFD68, 0xFF45, 0xFE83, 0xFEE4, 0xFF04, 0xFEE4, 0xFEC4, 0xFE63, 0xDB82, 0x8803, 0x30C3, 0xA514, // 0x00A0 (160) pixels
0xF7BE, 0xFFFF, 0x0986, 0xA001, 0xFDE8, 0xFFC5, 0x8B62, 0x2901, 0x3142, 0x2901, 0x8B83, 0xFF23, 0xF443, 0x6800, 0x1185, 0xF7BE, // 0x00B0 (176) pixels
0xF7BE, 0xFFFF, 0x9514, 0x4063, 0xD1E4, 0xFEE7, 0xD604, 0x8C02, 0x8C42, 0x8C02, 0xCD83, 0xFDA4, 0x9921, 0x3042, 0x9534, 0xF79E, // 0x00C0 (192) pixels
0xF79E, 0xFFFF, 0xFFFF, 0x9D76, 0x4864, 0x4100, 0xC343, 0xFBE5, 0xFC26, 0xFC06, 0xC303, 0x2860, 0x3023, 0x9D76, 0xFFFF, 0xF7BE, // 0x00D0 (208) pixels
0xF7BE, 0xF79E, 0xFFDF, 0xFFFF, 0x8CB3, 0x3A8B, 0x48A4, 0x5000, 0x5000, 0x5000, 0x50A4, 0x42AC, 0x8C92, 0xFFFF, 0xFFDF, 0xF7BE, // 0x00E0 (224) pixels
0xF7BE, 0xF7BE, 0xF79E, 0xF7BE, 0xF7BE, 0xF7BE, 0xAD55, 0x6B6D, 0x6B6D, 0x6B6D, 0xA534, 0xF7BE, 0xF7BE, 0xF7BE, 0xF7BE, 0xF7BE, // 0x00F0 (240) pixels
const unsigned short mario16x16[256] PROGMEM={
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFF7D, 0xE041, 0xD841, 0xD000, 0xC800, 0xC800, 0xC082, 0xFFBE, 0xFFDF, 0xFFDF, 0xFFFF, 0xFFFF, // 0x0010 (16) pixels
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xE000, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF000, 0xB000, 0xA800, 0xB000, 0xFFFF, 0xFFFF, // 0x0020 (32) pixels
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x29E1, 0x2A84, 0x4366, 0xBF57, 0xCFB8, 0xDFF9, 0x0000, 0xE7F9, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0030 (48) pixels
0xFFFF, 0xFFFF, 0xFFFF, 0x1000, 0xFFBB, 0x51C1, 0xFF59, 0xDE97, 0xE655, 0xF6D6, 0x0001, 0xE674, 0xDDF2, 0xB4AD, 0xFFFF, 0xFFFF, // 0x0040 (64) pixels
0xFFFF, 0xFFFF, 0xFFFF, 0x1000, 0xFFBB, 0x5A02, 0xEED7, 0xDE55, 0xDE55, 0xF717, 0xEEB6, 0x0000, 0xFF37, 0xC550, 0xC52F, 0xFFFF, // 0x0050 (80) pixels
0xFFFF, 0xFFFF, 0xFFFF, 0x0000, 0x28A0, 0xCDB2, 0xEEB6, 0xD614, 0xD5F3, 0xDE54, 0x0000, 0x0001, 0x0042, 0x0000, 0xFFFF, 0xFFFF, // 0x0060 (96) pixels
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xDED3, 0xDF58, 0xDEF4, 0xCED5, 0xE6D3, 0xE716, 0xFF54, 0xE632, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0070 (112) pixels
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xD000, 0xD800, 0x08DF, 0xD800, 0xD800, 0xE800, 0x001F, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0080 (128) pixels
0xFFFF, 0xFFFF, 0xFFFF, 0xE000, 0xF800, 0xF800, 0x19FF, 0xF800, 0xF800, 0x1A1F, 0xF000, 0xE000, 0xD800, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0090 (144) pixels
0xFFFF, 0xFFFF, 0xE000, 0xF800, 0xF800, 0xF800, 0x21BF, 0x315F, 0x213F, 0x217D, 0xF800, 0xF800, 0xF800, 0xC800, 0xFFFF, 0xFFFF, // 0x00A0 (160) pixels
0xFFFF, 0xFFFF, 0xADB0, 0xCFFA, 0xF800, 0x111F, 0xFFE0, 0x491E, 0x4958, 0xFFE0, 0x005B, 0xF800, 0xC7FB, 0xADD1, 0xFFFF, 0xFFFF, // 0x00B0 (176) pixels
0xFFFF, 0xFFFF, 0xBD0E, 0xE777, 0xDEF0, 0x289F, 0x491E, 0x40DC, 0x40FA, 0x38B9, 0x1878, 0xE751, 0xE777, 0xBD0F, 0xFFFF, 0xFFFF, // 0x00C0 (192) pixels
0xFFFF, 0xFFFF, 0xBD0E, 0xDE2F, 0x181C, 0x597F, 0x48FC, 0x38B7, 0x3896, 0x40F9, 0x40D8, 0x0815, 0xE670, 0xC52E, 0xFFFF, 0xFFFF, // 0x00D0 (208) pixels
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x281F, 0x491F, 0x303A, 0xFFFF, 0xFFFF, 0x1015, 0x30B9, 0x2819, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x00E0 (224) pixels
0xFFFF, 0xFFFF, 0xFFFF, 0x4120, 0x72C1, 0x7B20, 0x30A0, 0xFFFF, 0xFFFF, 0x4120, 0x8341, 0x6240, 0x30A0, 0xFFFF, 0xFFFF, 0xFFFF, // 0x00F0 (240) pixels
0xFFFF, 0xFFFF, 0x6A85, 0x6265, 0x6244, 0x5A03, 0x5A04, 0xFFFF, 0xF7BE, 0x5A24, 0x5A03, 0x51E3, 0x49A2, 0x41A3, 0xFFFF, 0xFFFF, // 0x0100 (256) pixels
const unsigned short ks1[144] PROGMEM={
0xE737, 0xF7BC, 0xF77C, 0xC594, 0x93CE, 0xA491, 0xE6DA, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB4D1, 0x4964, 0x6A48, 0x59C6, 0x49A5, // 0x0010 (16) pixels
0xFFFF, 0xFFFF, 0xDE99, 0x3924, 0xB471, 0xCCF3, 0xEDD7, 0xEDF8, 0xC556, 0x5A69, 0xB596, 0xACD2, 0x8B0B, 0xEDD6, 0xD4D3, 0xD534, // 0x0020 (32) pixels
0xE5D8, 0xE5F8, 0xAC0F, 0x83CF, 0x9430, 0xDCD1, 0xD4D3, 0xC4B2, 0xC4B3, 0xCCD3, 0xCCB2, 0xC40E, 0x732D, 0x8BAE, 0xDCF0, 0xC470, // 0x0030 (48) pixels
0xC4B2, 0xC514, 0xC4F4, 0xC471, 0xAB8C, 0x7B4D, 0x93CE, 0xE552, 0xD514, 0xBC71, 0xCCD3, 0xCCD3, 0xC471, 0xC470, 0x8BAE, 0xAC0F, // 0x0040 (64) pixels
0xD4F2, 0x728A, 0x4903, 0x92EA, 0x7A27, 0x4144, 0x938E, 0x93CF, 0xB491, 0xA36D, 0x6A6A, 0x6A6A, 0xCC92, 0xA38E, 0x5A08, 0x7A69, // 0x0050 (80) pixels
0x9BCF, 0xBD13, 0xDCF4, 0xD535, 0xC451, 0xE515, 0xCCD3, 0xBC10, 0xDC93, 0xAC31, 0xBD55, 0xBBAD, 0x9AEB, 0x92EB, 0xCC31, 0xAB8E, // 0x0060 (96) pixels
0x8AAA, 0x92AA, 0x9C31, 0xB555, 0x9B8C, 0x61A6, 0xAB8E, 0x824A, 0x828A, 0x930C, 0x61C5, 0x9C72, 0xB556, 0xAC91, 0x934C, 0x92EC, // 0x0070 (112) pixels
0x830C, 0x7AAC, 0x92CB, 0x8B4C, 0xA4D3, 0xB555, 0xBB0D, 0x9BCD, 0xB3EF, 0x92AC, 0x92CC, 0xABCD, 0x49C8, 0x6B0E, 0x82CE, 0x8887, // 0x0080 (128) pixels
0x9BCD, 0xB451, 0xC431, 0xBC51, 0xA42F, 0x2002, 0x18C5, 0x3107, 0x68C6, 0x6967, 0x8B0B, 0x934D, 0x8B0C, 0x8B2C, 0x58C6, 0x1084, // 0x0090 (144) pixels
matrix.begin();
int pass = 0;
//matrix.fillScreen(0);
//matrix.setCursor(x, 0);
// matrix.clear();
// matrix.drawRGBBitmap(0, 0, (const uint16_t *)ks1, 16, 16);
// matrix.show();
// delay(3000);
matrix.drawRGBBitmap(0, 0, (const uint16_t *)ironMan16x16, 16, 16);
matrix.show();
delay(3000);
matrix.clear();
matrix.drawRGBBitmap(0, 0, (const uint16_t *)mario16x16, 16, 16);
matrix.show();
delay(3000);
// //matrix.print(F("If you can read this, please answer the question: are you male?"));
// //matrix.print(F("IIIIII"));
// matrix.print(F("HELLO PEOPLE OF WILLIS"));
// if(--x < -120) {
// x = matrix.width();
// if(++pass >= 3) pass = 0;
// matrix.setTextColor(colors[pass]);
// //matrix.setTextColor(colors[2]);
// matrix.show();
// delay(100);
#ifndef PSTR
#endif
#define PIN 6
matrix.begin();
int pass = 0;
// matrix.clear();
// matrix.show();
// delay(3000);
matrix.show();
delay(3000);
matrix.clear();
matrix.show();
delay(3000);
// if(--x < -120) {
// matrix.show();
// delay(100);
- ironManDebug.jpg (121.29 KiB) Viewed 217 times
- adafruit_support_carter
It looks like it's working? For the first example, that's just the size of the font being used.
- keithschaub
Thanks for your response.
Is there a way to increase the size of the font so that it uses more of the 16 rows? (It only uses 7).
There's no scaling of fonts available. So you'll just need to swap to using a different size font:
https://learn.adafruit.com/adafruit-gfx ... sing-fonts
