Good morning, please find attached a PDF file with a diagram of the wiring configuration involved.
In summary:
- 4 LED panels each 64x32
- an external 5vdc power supply up to 10 amps output
- Adafruit Matrix Portal
- PC with a USB-C connection
Matrix Portal does not appear on PC depending on power supply connection sequence.
Is there a solution for this issue, I wish to connect to the matrix portal with any sequence.
Regards
Matrix Portal Connectivity - sequence dependant
- Azzura
- Matrix Portal Connectivity V0.pdf
- (488.36 KiB) Downloaded 7 times
Re: Matrix Portal Connectivity - sequence dependant
Post a photo showing your actual hardware and connections please.
Diagrams show how things are supposed to be. Hardware shows how things really are.
800x600 images usually work best.
- Rebtop
is Blue Tooth supported?
