Adafruit AirLift - ESP32 WiFi Co-Processor Breakout
galloups
Post by galloups »
Hello Adafruit team.
I am currently using Airlifts breakouts with:
  • Raspberry Pi Pico running Circuit Python (WIFI and BLE projects)
    Arduino (WIFI projects)
Firmware version is 1.7.4
I wanted to know if there were plans to port Airlift BLE library to Arduino, as today it is only available with Circuit Python?
Another question: today Airlift BLE library for Circuit Python does not allow to set the 3 leds of the ESP32. It is only possible in WIFI mode using the esp32 with SPI. Is that something that could be added to BLE library? Having access to 3 leds without having to hook up anything on the breadboard is a real plus!
Thank you!
law1
Re: Adafruit AirLift - ESP32 WiFi Co-Processor Breakout
Post by law1 »
I am also hopeful for some guidance using AirLift ESP32 Breakout module with Feather M4 Express. I hope to add BLE capabilities to my existing advanced ADS1262 ADC project for ADC controls and status indicators. This project is using Arduino IDE and includes very high-speed recording to SD with dedicated SPI and stacked Adafruit GPS/RTC module on Serial connection. I would hope there are some means to access the ESP32 coprocessor capabilities advertised to this Adafruit breakout module.
I hope to avoid using the WiFi capabilities to reserve the dedicated SPI to the ADC recording of the ADS1262.
Any advice is sincerely appreciated.
Analog_data_logger_ADS1262_schematic.pdf
(273.76 KiB) Downloaded 8 times
law1
Post by law1 »
With some struggle I have managed a way to "pre-program" the AirLift ESP32 breakout with simple SerialToSerialBT using a Adafruit CP2102N Friend - USB to Serial Converter ($5.95). Albeit there may be other ways using the "serial-pass-thru" mumbo-jumbo, I was unable to determine how to handle that thru my Feather M4 Express in Arduino.
Wiring: AirLift ESP32 breakout > USB to Serial Converter
Vin 5V > 5V
Gnd > Gnd
RST > RTS
GP0 > DTR
RXI > TXD
TX0 > RXD
In Arduino IDE select the ESP32 Arduino & Adafruit Feather (or ESP32 Dev Module) board selection after adding "https://dl.espressif.com/dl/package_esp32_index.json" to the Preferences/Additional Boards Manger URLs: and additionally, to assure the CP2102N Friend com port drivers are loaded and a new com(x) discovered. Then just compile/load the example sketch(s) to the AirLift ESP32. (I've used SerialToSerialBT example under "BluetoothSerial", others possible).
I hope this simplicity is helpful in your developments of BLE capabilities of the AirLift ESP32 breakout.
