Hello!
I understand that this https://www.adafruit.com/product/744 cable is waterproofed when it is connected. But when two parts are disconnected, are they able to resist water.
Also, is it possible to use this https://www.adafruit.com/product/5358 as a waterproof connector?
Need waterproofed connectors
- adafruit_support_mike
Re: Need waterproofed connectors
No. The connection is only waterproof once the gland is screwed shut. Inside, the conductors have to be exposed so they can connect to each other.kise1_off wrote:But when two parts are disconnected, are they able to resist water.
Not even remotely. The conductors are fully exposed on both sides of each half.kise1_off wrote:Also, is it possible to use this https://www.adafruit.com/product/5358 as a waterproof connector?
