VL53L1X ToF Sensor - usage of XSHUT-Pin/change default addr
hespHB
Post by hespHB »
I am working on an object detection system for an inventory drone and would like to use data from multiple VL53L1X ToF sensors to determine distance. To use the data from the i2c interface, I wanted to switch the sensors via the XSHUT pin to differentiate the sensors. Unfortunately, I find relatively little / nothing at all to implement this and have derived the basic logic based on the data sheet. Only unfortunately my solution does not work and does not generate me the desired result.
Therefore I have the following questions:
1. Is there a logic error in my code, why the change does not work? (Code and output are a little deeper)
2. Is my my circuit/use of the pins not correct?
3. Is there a way to change the address of the sensor during the boot process? So each sensor could write directly to the bus via its own address.
I appreciate any feedback and thank you in advance.
import time
import board
import adafruit_vl53l1x
import RPi.GPIO as GPIO
# define XSHUT pins to switch between the sensors
GPIO.setmode(GPIO.BCM)
GPIO_XSHUT_1 = 20
GPIO_XSHUT_2 = 21
GPIO.setup(GPIO_XSHUT_1, GPIO.OUT)
GPIO.setup(GPIO_XSHUT_2, GPIO.OUT)
# set pins on HIGH to allow a i2c connection
GPIO.output(GPIO_XSHUT_1,  GPIO.HIGH )
GPIO.output(GPIO_XSHUT_2,  GPIO.HIGH )
time.sleep(1.0)
i2c = board.I2C()
vl53 = adafruit_vl53l1x.VL53L1X(i2c)
# define sensor mode
vl53.distance_mode = 2
vl53.timing_budget = 100
vl53.start_ranging()
try:
    while True:
        if vl53.data_ready:
            # read first sensor (1->HIGH ; 2->LOW)
            GPIO.output(GPIO_XSHUT_2,  GPIO.LOW )
            time.sleep(1.0)
            distance = vl53.distance
            print("Distance: {} cm at pin {}".format(vl53.distance, GPIO_XSHUT_1))
            vl53.clear_interrupt()
            GPIO.output(GPIO_XSHUT_1,  GPIO.LOW )
            # read second sensor (1->LOW ; 2->HIGH)
            print("Distance: {} cm at pin {}".format(vl53.distance, GPIO_XSHUT_2))
            time.sleep(1.0)
        else:
            print("waiting for sensor data...")
            time.sleep(1.0)
except KeyboardInterrupt:
    print("Stop")
    GPIO.cleanup()
Generated output from the code:
Distance: 7.0 cm at pin 12
Distance: 0.0 cm at pin 16
adafruit_support_carter
Re: VL53L1X ToF Sensor - usage of XSHUT-Pin/change default
Highly recommend using an I2C multiplexer to deal with this issue:
https://learn.adafruit.com/adafruit-tca ... r-breakout
https://learn.adafruit.com/working-with ... 2c-devices
Otherwise, you'll need to go through an initiation for each sensor using XSHUT. This is for a different model, but it's the same idea:
The equivalent to VL53LX_SetDeviceAddress() is set_address() in the CircuitPython library.
EDIT:
oh, yah, forgot, there's actually an example for this in the library repo:
https://github.com/adafruit/Adafruit_Ci ... sensors.py
hespHB
Post by hespHB »
Thank you for the quick feedback and the tip with the multiplexer. If I do not get further on the software side, it will be ordered directly.
However, when running the library example, I get the following error message:
/usr/bin/python3 /home/pi/DroneStock/VL53L1X/adafruit/vl53l1x_set_address_multiple_sensors.py
  File "/home/pi/DroneStock/VL53L1X/adafruit/vl53l1x_set_address_multiple_sensors.py", line 53, in <module>
    sensor_i2c.set_address(pin_number + 0x30)
AttributeError: 'VL53L1X' object has no attribute 'set_address'
I tried to install all necessary/prescribed dependencies from the git repo (https://github.com/adafruit/Adafruit_Ci ... on_VL53L1X). When installing "circup install vl53l1x" I still get the following error:
Version 1.0.3 of circup is outdated. Version 1.0.4 was released Friday February 18, 2022.
Could not find a connected CircuitPython device.
If I try to update it afterwards with the "circup update" it stays at the outdated release version and throws the same error message.
Could this be related? Alternatively, I had tried to overwrite the address directly when instantiating the sensor by
import time
import board
i2c = board.I2C()
#-----try to initialize another bus address with the hex and dezimal numbers
# hex to dezimal -> 0x29=41
vl53_left = adafruit_vl53l1x.VL53L1X(i2c, address=0x29)
# hex to dezimal -> 0x30=48
vl53_right = adafruit_vl53l1x.VL53L1X(i2c, address=0x30)
vl53_left.start_ranging()
vl53_right.start_ranging()
while True:
    if vl53_left.data_ready :
        print("Left: {} cm".format(vl53_left.distance))
        vl53_left.clear_interrupt()
        print("Right: {} cm".format(vl53_right.distance))
        vl53_right.clear_interrupt()
        time.sleep(1.0)[
/code]
, but also here I got only an error:
[code]
/usr/bin/python3 /home/pi/DroneStock/VL53L1X/adafruit/change_addr.py
  File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 154, in __probe_for_device
    self.i2c.writeto(self.device_address, b"")
  File "/home/pi/.local/lib/python3.7/site-packages/busio.py", line 169, in writeto
    return self._i2c.writeto(address, buffer, stop=stop)
  File "/home/pi/.local/lib/python3.7/site-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 52, in writeto
    self._i2c_bus.write_bytes(address, buffer[start:end])
  File "/usr/local/lib/python3.7/dist-packages/Adafruit_PureIO/smbus.py", line 314, in write_bytes
    self._device.write(buf)
OSError: [Errno 121] Remote I/O error
During handling of the above exception, another exception occurred:
  File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 160, in __probe_for_device
    self.i2c.readfrom_into(self.device_address, result)
  File "/home/pi/.local/lib/python3.7/site-packages/busio.py", line 159, in readfrom_into
    return self._i2c.readfrom_into(address, buffer, stop=stop)
  File "/home/pi/.local/lib/python3.7/site-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 59, in readfrom_into
    readin = self._i2c_bus.read_bytes(address, end - start)
  File "/usr/local/lib/python3.7/dist-packages/Adafruit_PureIO/smbus.py", line 181, in read_bytes
    return self._device.read(number)
  File "/home/pi/DroneStock/VL53L1X/adafruit/change_addr.py", line 10, in <module>
  File "/usr/local/lib/python3.7/dist-packages/adafruit_vl53l1x.py", line 79, in __init__
    self.i2c_device = i2c_device.I2CDevice(i2c, address)
  File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 50, in __init__
    self.__probe_for_device()
  File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 163, in __probe_for_device
    raise ValueError("No I2C device at address: 0x%x" % self.device_address)
ValueError: No I2C device at address: 0x30
And again, thanks for any help with my problem!
You may have an older version of the VL53L1X library. The address setting function was added fairly recently:
https://github.com/adafruit/Adafruit_Ci ... /tag/1.1.0
So it may be related to the circup issue? You can try manually downloading the latest library bundle and copying the library from there.
https://learn.adafruit.com/welcome-to-c ... -libraries
hespHB
Post by hespHB »
So this has partially worked for me. But I´m still facing to the same error as before. The libary is updated and knows the methods (you can see ist in the picture), but if I want to run the code this error apperas:
  File "/home/pi/DroneStock/VL53L1X/adafruit/vl53l1x_set_address_multiple_sensors.py", line 57, in <module>
I checked manually the libary and everything is up to date. Do you have any idea where the last error/problem could be? I checked my wiring and everything seems okay. Meanwhile I ordered a multiplexer so maybe this could solve my problem. Another option would be to define a new i2c bus on my raspberry pi and try to to connect and read out the second sensor. (https://www.instructables.com/Raspberry ... c-Devices/)
Thanks for any help and sorry for the late reply!
Sorry, ignore my previous suggestion about using the Library Bundle. Forgot you were using a Pi.
For a Pi, libraries are installed via pip.
https://learn.adafruit.com/adafruit-vl5 ... 3105069-10
Library updating would also be done with pip.
How did you update the library? What specific command did you use?
hespHB
Post by hespHB »
No problem :D
By now, I think I tried every possible commad. I´ve tried it with:
1. pip install adafruit-circuitpython-vl53l1x
Output:
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: adafruit-circuitpython-vl53l1x in /usr/local/lib/python3.7/dist-packages (1.0.2)
Requirement already satisfied: adafruit-circuitpython-busdevice in /usr/local/lib/python3.7/dist-packages (from adafruit-circuitpython-vl53l1x) (5.1.2)
Requirement already satisfied: Adafruit-Blinka in ./.local/lib/python3.7/site-packages (from adafruit-circuitpython-vl53l1x) (7.3.0)
Requirement already satisfied: pyftdi>=0.40.0 in /usr/local/lib/python3.7/dist-packages (from Adafruit-Blinka->adafruit-circuitpython-vl53l1x) (0.53.1)
Requirement already satisfied: Adafruit-PlatformDetect>=3.13.0 in /usr/local/lib/python3.7/dist-packages (from Adafruit-Blinka->adafruit-circuitpython-vl53l1x) (3.14.0)
Requirement already satisfied: rpi-ws281x>=4.0.0 in /usr/local/lib/python3.7/dist-packages (from Adafruit-Blinka->adafruit-circuitpython-vl53l1x) (4.3.0)
Requirement already satisfied: RPi.GPIO in /usr/local/lib/python3.7/dist-packages (from Adafruit-Blinka->adafruit-circuitpython-vl53l1x) (0.7.1)
Requirement already satisfied: Adafruit-PureIO>=1.1.7 in /usr/local/lib/python3.7/dist-packages (from Adafruit-Blinka->adafruit-circuitpython-vl53l1x) (1.1.9)
Requirement already satisfied: sysv-ipc>=1.1.0 in /usr/local/lib/python3.7/dist-packages (from Adafruit-Blinka->adafruit-circuitpython-vl53l1x) (1.1.0)
Requirement already satisfied: adafruit-circuitpython-typing in ./.local/lib/python3.7/site-packages (from Adafruit-Blinka->adafruit-circuitpython-vl53l1x) (1.6.0)
Requirement already satisfied: pyusb>=1.0.0 in /usr/local/lib/python3.7/dist-packages (from pyftdi>=0.40.0->Adafruit-Blinka->adafruit-circuitpython-vl53l1x) (1.1.1)
Requirement already satisfied: pyserial>=3.0 in /usr/lib/python3/dist-packages (from pyftdi>=0.40.0->Adafruit-Blinka->adafruit-circuitpython-vl53l1x) (3.4)
Requirement already satisfied: typing-extensions; python_version <= "3.7" in ./.local/lib/python3.7/site-packages (from adafruit-circuitpython-typing->Adafruit-Blinka->adafruit-circuitpython-vl53l1x) (3.10.0.0)
pi@knxpi:~ $
2. sudo pip install adafruit-circuitpython-vl53l1x ...to guarantee a system-wide installation
Output:
Requirement already satisfied: Adafruit-Blinka in /usr/local/lib/python3.7/dist-packages (from adafruit-circuitpython-vl53l1x) (7.3.0)
Requirement already satisfied: adafruit-circuitpython-typing in /usr/local/lib/python3.7/dist-packages (from Adafruit-Blinka->adafruit-circuitpython-vl53l1x) (1.6.0)
Requirement already satisfied: typing-extensions; python_version <= "3.7" in /usr/local/lib/python3.7/dist-packages (from adafruit-circuitpython-typing->Adafruit-Blinka->adafruit-circuitpython-vl53l1x) (4.2.0)
3. And for the last time I tried it with "pip3 install adafruit-circuitpython-vl53l1x"
Output:
Requirement already satisfied: Adafruit-Blinka in /home/pi/.local/lib/python3.7/site-packages (from adafruit-circuitpython-vl53l1x) (7.3.0)
Requirement already satisfied: adafruit-circuitpython-typing in /home/pi/.local/lib/python3.7/site-packages (from Adafruit-Blinka->adafruit-circuitpython-vl53l1x) (1.6.0)
Requirement already satisfied: typing-extensions; python_version <= "3.7" in /home/pi/.local/lib/python3.7/site-packages (from adafruit-circuitpython-typing->Adafruit-Blinka->adafruit-circuitpython-vl53l1x) (3.10.0.0)
This should be a similiar output for everything with different commands. After running the commands once more, the error ( from my last reply) still apperas if I want to run the script.
Looks like you have the 1.0.2 release installed:
And it's seeing that as "already installed, nothing to do".
Try forcing an update so it'll bring in the latest release:
pip install --upgrade adafruit-circuitpython-vl53l1x
hespHB
Post by hespHB »
This has solved my problem, the sensors are running and they are detected with diffrent addresses if I use "sudo i2cdetect -y 1".
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- 29 -- -- -- -- -- --
30: 30 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Thanks for your support and help!
