AHT20 led on but not found on i2c
ckdake
Post by ckdake »
Hello! First project with some adafruit bits, and first snag:
This is a https://www.adafruit.com/product/4566 connected via a https://www.adafruit.com/product/4210 to a https://www.adafruit.com/product/4463 to a pi B+. Green led is on on the sensor so i know it is getting power at least. Photo attached of setup.
I've followed steps on https://learn.adafruit.com/circuitpytho ... spberry-pi and i2c looks like it is up and running:
$ python3 blinkatest.py
Hello blinka!
Digital IO ok!
I2C ok!
SPI ok!
done!
But alas, when I try and use the AHT20 with:
import time
import board
import adafruit_ahtx0
# Create sensor object, communicating over the board's default I2C bus
i2c = board.I2C()  # uses board.SCL and board.SDA
sensor = adafruit_ahtx0.AHTx0(i2c)
while True:
    print("\nTemperature: %0.1f C" % sensor.temperature)
    print("Humidity: %
I get:
ValueError: No I2C device at address: 0x38
First boot I had the cable on the wrong side of the AHT20 and the LED didn't turn on, but correcting that -> the LED on the sensor is on. I tried reversing the cable, no change there either.
I've spent some time poking around to troubleshoot, but I'm at a loss here. Any ideas/suggestions?
dastels
Re: AHT20 led on but not found on i2c
Post by dastels »
I'm very skeptical of those "skim" boards, especially for a high speed data signal like I2C. Do you have something like https://www.adafruit.com/product/4397 that you can connect the sensor with, i.e. not using the shim? that will give you a better connection and give a better idea what the problem is. You would need to connect the STEMMA_QT power line to the Pi's 3.3v pin. Alternatively you could solder some female header on the bottom of the shim.
ckdake
Post by ckdake »
Thanks, it does seem like a not-quite-snug connection. The cable you linked has been out of stock so I didn't order one, and my parts bin here is limited to wires and shrinkwrap at this point. I'll see if I can get my hands on something else to get a better connection and report back.
ckdake
Post by ckdake »
Yep, proper wires did the trick and I have temperature and humidity now!
dastels
Post by dastels »
Awesome! Those shims are sound great in theory but in practice have too many potential points of failure.
