Hi Everyone,
I would like to buy a screen and some sensors to create animated graphics. I have no Idea where to start for creating the UI.
It would be something a bit in the same style as teenage engineering style. There would be pre existing shape that would appear or not (like old analogue screen) depending on some variables. Is there a software to create those that could be loaded onto an arduino for exemple? or should it be something more like a Pi with a small program on it?
I know how to make the graphics (illustrator) and animate them (After effect) but It's not "live". What tools could I use to do that?
Thanks in advance
Paul
UI coding
- dastels
Re: UI coding
I suggest a high end Feather with lots of RAM for bitmaps (e.g. https://www.adafruit.com/product/3857 or even better https://www.adafruit.com/product/4884) and a TFT FeatherWing (e.g. https://www.adafruit.com/product/3315 or https://www.adafruit.com/product/3651). You can connect sensors using I2C (the Feather RP2040 has the advantage of having a STEMMA-QT connector for I2C which provides an easy, solder-free way to connect sensors.
Both those Feathers are great platforms for CircuitPython, and you can start look at CircuitPython and DisplayIO guides. E.g. https://learn.adafruit.com/welcome-to-circuitpython, https://learn.adafruit.com/circuitpytho ... -displayio, https://learn.adafruit.com/making-a-pyp ... -displayio, and https://learn.adafruit.com/circuitpytho ... g-toasters will give you a good start.
- Pauldut
Re: UI coding
Hi Dave,
Thanks, it seems to be exactly what I need!
Paul
Paul
