solar panel generates more energy than needed
- garberw
Specs: my project uses about 600 mA at 5V max I expect. It is a raspberry pi zero 2 W and an ADC and some lower current breakouts. If I have a 6V 9W colossal solar panel and a bq24074 breakout and a 6600mAh battery what happens to the excess energy received by the panel after the battery is fully charged and the cpu is at peak? It is designed to go a week with no sunlight.
- adafruit_support_bill
Re: solar panel generates more energy than needed
The bq24074 has a load-sharing circuit. When the charge cycle is complete, current will stop flowing to the battery. The bq24074 will draw enough to power the chip and the power-good indicator LED. And it will route power from the panel to the load so the load can draw what it needs.
- garberw
- sj_remington
It is discarded as heat.what happens to the excess energy received by the panel
- garberw
Do you mean heat in the solar panel or heat in the bq24074?
- sj_remington
Both.
Think about what happens when you put a solar panel in the sun, but don't connect it to anything.
