I'm having a bit of trouble with the touch on a 7" display using a Adafruit RA8875 controller board, the unfortunate thing is that the display is an eBay 7" 40 pin TFT. The display part works great its the touch I'm having problems with. Doesn't matter how fast I touch or what I use, a finger or stylus I always get 4 touch point data. The other strange thing is that the 1st 2 are very close to each other and the last 2 are way off from the 1st
This is the serial output from touching the top left corner
Got Touch
51 , 60
Got Touch
51 , 61
Got Touch
457 , 152
Got Touch
563 , 87
Is this a compatibly issue and can it be fixed?
RA8875 Touch help
Re: RA8875 Touch help
Without a datasheet there's no way to say for sure.
Try getting readings for a grid of points across the surface and see if you can find any patterns in the results.
