Need help with beam breakers!
Neuro_Yanko
Post by Neuro_Yanko »
Hey there! I've been trying a long while to make the beam breakers https://learn.adafruit.com/ir-breakbeam ... s/overview work but didn't succeed.
I use them with a feather NRF52832 board, red wires connected to 3.3 V pins, black wires to ground, a yellow wire to physical pin 4 (0.27). I use the following script and it loops at "print 1111" stage.
How can I bring it to "print unbroken" state?
  IR Breakbeam sensor demo!
#define LEDPIN 31
#define SENSORPIN 4
// variables will change:
int sensorState = 0, lastState=0;         // variable for reading the pushbutton status
  // initialize the LED pin as an output:
  pinMode(LEDPIN, OUTPUT);
  // initialize the sensor pin as an input:
  pinMode(SENSORPIN, INPUT);
  digitalWrite(SENSORPIN, HIGH); // turn on the pullup
  Serial.begin(9600);
void loop(){
  // read the state of the pushbutton value:
  sensorState = digitalRead(SENSORPIN);
  // check if the sensor beam is broken
  // if it is, the sensorState is LOW:
  if (sensorState == LOW) {
    // turn LED on:
    digitalWrite(LEDPIN, HIGH);
    Serial.println("1111");
  else {
    // turn LED off:
    digitalWrite(LEDPIN, LOW);
    Serial.println("2222");
  if (sensorState && !lastState) {
    Serial.println("Unbroken");
  if (!sensorState && lastState) {
    Serial.println("Broken");
  lastState = sensorState;
Re: Need help with beam breakers!
This trick works with the original Atmega-based Arduinos. It does not work with some of the other processor architectures. Use INPUT_PULLUP in your pinmode statement instead.
https://www.arduino.cc/reference/en/lan ... o/pinmode/
Neuro_Yanko
Hello, thank you!
Unfortunately, it didn't help (I might behave done it wrong), could you please have a look at this?
Now it only prints "sensorState"
#define LEDPIN 13
#define SENSORPIN 4
  pinMode(SENSORPIN, INPUT_PULLUP);
  Serial.begin(9600);
  sensorState = 0;
void loop(){
    // turn LED on:
    Serial.println(sensorState);
  else {
    // turn LED off:
  delay(1000);
You only need the pinMode command with INPUT_PULLUP. No need to explicitly set the pin HIGH.
With some processors, any write will set the pin back to output mode.
So delete this line:
