I tried to use both the codes directly from the Adafruit example library (sensortest and offsets) with both I2C and SPI wiring configurations, but the data I received was all cut off at +-25g (+- ~245 m/s^2) no matter how violent the impact was. The only part of the code that I modified was reducing the delay at the end of the void loop down from 500 to 1 ms to get faster data stream in which should not cause the sensor to saturate.
The link below seems to describe the same problem with the root cause being that the Data Format register (0x31) is set incorrectly from the factory. However, when I tried to rewrite the register, the outputs I get seem to be incorrect since I am easily able to get values in excess of 2000 m/s^2 (over 200g) and a 1g field is showing as ~120 m/s^2. Does anyone see errors in my code or should I try anything else to get the correct +-200g range output.
https://ez.analog.com/mems/f/q-a/89100/ ... ion/167287
If anyone has suggestions, please provide example code since I am a novice programmer.
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_ADXL375.h>
#define ADXL375_SCK 13
#define ADXL375_MISO 12
#define ADXL375_MOSI 11
#define ADXL375_CS 10
/* Assign a unique ID to this sensor at the same time */
/* Uncomment following line for default Wire bus */
Adafruit_ADXL375 accel = Adafruit_ADXL375(12345);
/* Uncomment for SPI */
//Adafruit_ADXL375 accel = Adafruit_ADXL375(ADXL375_SCK, ADXL375_MISO, ADXL375_MOSI, ADXL375_CS, 12345);
void displayDataRate(void)
Serial.print ("Data Rate: ");
switch(accel.getDataRate())
case ADXL343_DATARATE_3200_HZ:
Serial.print ("3200 ");
break;
case ADXL343_DATARATE_1600_HZ:
Serial.print ("1600 ");
break;
case ADXL343_DATARATE_800_HZ:
Serial.print ("800 ");
break;
case ADXL343_DATARATE_400_HZ:
Serial.print ("400 ");
break;
case ADXL343_DATARATE_200_HZ:
Serial.print ("200 ");
break;
case ADXL343_DATARATE_100_HZ:
Serial.print ("100 ");
break;
case ADXL343_DATARATE_50_HZ:
Serial.print ("50 ");
break;
case ADXL343_DATARATE_25_HZ:
Serial.print ("25 ");
break;
case ADXL343_DATARATE_12_5_HZ:
Serial.print ("12.5 ");
break;
case ADXL343_DATARATE_6_25HZ:
Serial.print ("6.25 ");
break;
case ADXL343_DATARATE_3_13_HZ:
Serial.print ("3.13 ");
break;
case ADXL343_DATARATE_1_56_HZ:
Serial.print ("1.56 ");
break;
case ADXL343_DATARATE_0_78_HZ:
Serial.print ("0.78 ");
break;
case ADXL343_DATARATE_0_39_HZ:
Serial.print ("0.39 ");
break;
case ADXL343_DATARATE_0_20_HZ:
Serial.print ("0.20 ");
break;
case ADXL343_DATARATE_0_10_HZ:
Serial.print ("0.10 ");
break;
default:
Serial.print ("???? ");
break;
Serial.println(" Hz");
void setup(void)
Serial.begin(115200);
while (!Serial);
Serial.println("ADXL375 Accelerometer Test"); Serial.println("");
/* Initialise the sensor */
if(!accel.begin())
/* There was a problem detecting the ADXL375 ... check your connections */
Serial.println("Ooops, no ADXL375 detected ... Check your wiring!");
while(1);
/* Display some basic information on this sensor */
accel.printSensorDetails();
displayDataRate();
Serial.println("");
void loop(void)
/* Get a new sensor event */
sensors_event_t event;
accel.getEvent(&event);
/* Display the results (acceleration is measured in m/s^2) */
Serial.print("X: "); Serial.print(event.acceleration.x); Serial.print(" ");
Serial.print("Y: "); Serial.print(event.acceleration.y); Serial.print(" ");
Serial.print("Z: "); Serial.print(event.acceleration.z); Serial.print(" ");Serial.println("m/s^2 ");
delay(1);
//code with adjusting 0x31 register
#include <Wire.h>
break;
break;
break;
break;
break;
break;
break;
break;
break;
break;
break;
break;
break;
break;
break;
break;
default:
break;
void setup(void)
while (!Serial);
if(!accel.begin())
while(1);
// Code addition to attempt to fix 25g saturation by rewriting data format register
Wire.beginTransmission(0x53); // Device address per data sheet
Wire.write(0x31); // data format register
Wire.write(0b00001111); // write bits as suggested in forum
Wire.endTransmission();
displayDataRate();
Serial.println("");
void loop(void)
delay(1);
