Hi there,
I have the MPRLS Ported Pressure Sensor Breakout connected to a custom board with a Xilinx Versal chip running a custom Linux OS built by PetaLinux. I plan to interact with the sensor in software via the C/C++ i2c-dev framework instead of using the Arduino library (because the board is not an Arduino) or the CircuitPython library (because the board does not have Python installed). Is this feasible? If so, are there instructions on how to configure the device tree to include the sensor- namely the name of the Linux kernel driver that I would need for the device tree node's "compatible" property, interrupt properties, and any other special device properties that I would need to set? In addition, are there any properties in PetaLinux aside from enabling i2c-dev that I would need to set? If none of this is possible, since it is running a Linux OS, is using the CircuitPython library the only viable option that I have?
- Lena
MPRLS Pressure Sensor question
Re: MPRLS Pressure Sensor question
Maybe? It mostly depends on the existence of I2C support in the codebase for your custom Linux.lenlope wrote:Is this feasible?
Assuming you can do I2C, you can use our libraries as working code references for a driver.
Not a clue.. custom Linux distros usually remove all the standard runtime utilities and replace them with a single binary that provides a subset of the usual features. Your best bet will be to look through the documentation for PetaLinux and see how it handles I2C and/or the device tree.lenlope wrote:If so, are there instructions on how to configure the device tree to include the sensor- namely the name of the Linux kernel driver that I would need for the device tree node's "compatible" property, interrupt properties, and any other special device properties that I would need to set? In addition, are there any properties in PetaLinux aside from enabling i2c-dev that I would need to set? If none of this is possible, since it is running a Linux OS, is using the CircuitPython library the only viable option that I have?
- lenlope
Thanks for the response! I think we have path forward on this to figure out how to configure it in PetaLinux, though at the same time, we will also look into including the CircuitPython library. If anything, that might also help us to troubleshoot the interface faster.
