Matrix Portal M4 Error
sunbake
Post by sunbake »
Been following this tutorial using the hardware listed on it, but I'm not getting the Creature Eyes.
https://learn.adafruit.com/matrix-porta ... s/overview
The attached image shows what is displayed instead.
It works fine when running the sand demo: https://learn.adafruit.com/adafruit-mat ... -dust-demo
What am I doing wrong?
dastels
Re: Matrix Portal M4 Error
Post by dastels »
If it runs the sand demo ok then the hardware is connected correctly and functioning.
You're seeing the circuitPython "terminal" output. The code isn't running for some reason. I suspect some file missing.
Can you post what you see in the REPL when the code runs? That should give a better idea of what's happening.
If you aren't familiar with using the REPL (or even just the serial connection), see
https://learn.adafruit.com/welcome-to-c ... al-console
https://learn.adafruit.com/welcome-to-c ... n/the-repl
sunbake
Post by sunbake »
Thank you for the links!
This is what is shown in the REPL:
Auto-reload is on. Simply save files over USB to run them or enter REPL to disable.
code.py output:
  File "code.py", line 68, in <module>
  File "code.py", line 56, in __init__
AttributeError: 'Sprite' object has no attribute 'height'
Code done running.
Again the code used is directly from here:
https://learn.adafruit.com/matrix-porta ... d-graphics
dastels
Post by dastels »
Are you running the latest version (7.3.0) of CircuitPython and the libraries/modules from the latest bundle?
If you need to update the contents of the CIRCUITPY/lib directory, be sure to delete everything in it first, empty trash, then copy in the latest.
ntynen
Post by ntynen »
I too am seeing this same error. I have downloaded the latest bundle and installed into the previously empty lib directory.
>>> %Run -c $EDITOR_CONTENT
File "<stdin>", line 68, in <module>
File "<stdin>", line 56, in __init__
dastels
Post by dastels »
Digging deeper I see that the complaint is about the assignment to height which generally is not the case. The "no attribute"error is typically when you access an attribute that isn't there. Assigning it is how it gets created. I'm looking into it.
sunbake
Post by sunbake »
dastels wrote:Are you running the latest version (7.3.0) of CircuitPython and the libraries/modules from the latest bundle?
Yes, I am running the latest version (7.3.0) including the latest libraries/modules. I'm only using the recommended libraries that was listed in the tutorial including the 'adafruit_imageload'. The list is found here:
https://learn.adafruit.com/matrix-porta ... thon-setup
neradoc
Post by neradoc »
Tilegrid has its own height property now, which is read only and can't be overridden by a subclass because it's a builtin.
Try removing line 56: "self.height = bitmap.height".
sunbake
Post by sunbake »
neradoc wrote:Try removing line 56: "self.height = bitmap.height".
Oh wow, it works perfectly! Thank you so much!
