the description for TLP5110 says you adjust the turn on time by turning the pot. Then it says if doesn't receive enable in the spoecified time it will turn off. How do you set the turn OFF time if there is only one pot? Also, if hittin the switch once turns poer on, will pressing a second time turn it back off?
TLP5110 time control
- dastels
Re: TLP5110 time control
The trim pot (or resistor if you replace the pot) sets the time from being turned off via DONE to turning back on. Call that T.
If it's turned on, you turn it off using DONE. If it doesn't get the turn off signal on DONE within time T - 50mS, it will turn off for 50mS before the timer turns it on again.
The switch (which shorts DELAY to ground, effectively overriding the timing resistor) turns it on. DONE turns it off (unless it times out as described above). Pressing the button again once it is on is ignored.
When you say enable, I think you mean DONE.
All the information is in the datasheet: https://cdn-learn.adafruit.com/assets/a ... pl5110.pdf
- Den1
I don't need it to turn on, I need to turn it on by pushing a switch, and turn off, by either timing out, or pushing the switch again. Can this be easily configured to do that? Or is there another device better suited for that task?
- dastels
You'll need something different. There are multiple ways you could do this, depending on what it's to be used for. If you want to describe the project, it might bew possible to make some suggestions.
- sj_remington
Take a look at the Pololu Power Switch. It seems to do exactly what you want.
https://www.pololu.com/category/121/pol ... r-switches
- Den1
Hi, The Pololu would require a seprate timer to turn off, no? I'm only trying to drive an LED by pushing button to turn on, then either turn off by pushing again, or turning off after say 15secs, which ever occurs first.
- dastels
You could always use a cheap/small microcontroller. Something like a Trinket or Gemma M0, or a QtPy.
