Matrix Arrived Damaged?
Deep90
Post by Deep90 »
I suspect my led matrix arrived damaged. Running the following code and you can see 2 parts of the matrix simply do not light up.
Same issue exists when running the pixel dust demo even after modifying the height for 64x64 matrixes.
#include <Adafruit_Protomatter.h>
uint8_t rgbPins[]  = {7, 8, 9, 10, 11, 12};
uint8_t addrPins[] = {17, 18, 19, 20, 21};
uint8_t clockPin   = 14;
uint8_t latchPin   = 15;
uint8_t oePin      = 16;
Adafruit_Protomatter matrix(
  64, 4, 1, rgbPins, 5, addrPins, clockPin, latchPin, oePin, false);
void setup(void) {
  Serial.begin(9600);
  // Initialize matrix...
  ProtomatterStatus status = matrix.begin();
  Serial.print("Protomatter begin() status: ");
  Serial.println((int)status);
  if(status != PROTOMATTER_OK) {
    for(;;);
  matrix.fillRect(0,0, 64, 64, matrix.color565(255,255,255));
  // AFTER DRAWING, A show() CALL IS REQUIRED TO UPDATE THE MATRIX!
  matrix.show(); // Copy data to matrix buffers
void loop(void) {
  Serial.print("Refresh FPS = ~");
  Serial.println(matrix.getFrameCount());
  delay(1000);
dastels
Re: Matrix Arrived Damaged?
Post by dastels »
Are all your board support packages and libraries up to date?
Have you set the address E jumper?
The code you posted worked fine for me. Hmm.. welll it lights all the leds.
Deep90
Post by Deep90 »
I ran through the setup instructions on the adafruit site.
Library's were all freshly installed.
E jumper looks to be set in code no? In addressing 5 pins.
dastels
Post by dastels »
There's a hardware jumper on the MatrixPortal to set which pin on the panel connector it goes to. there should be a connector pinout diagram on the back of the panel. E will be either 8 or 16. Se the jumper on the MatrixPortal to match (i.e. short the right part of the jumper). See https://learn.adafruit.com/adafruit-mat ... er-3072815
Deep90
Post by Deep90 »
dastels wrote:There's a hardware jumper on the MatrixPortal to set which pin on the panel connector it goes to. there should be a connector pinout diagram on the back of the panel. E will be either 8 or 16. Se the jumper on the MatrixPortal to match (i.e. short the right part of the jumper). See https://learn.adafruit.com/adafruit-mat ... er-3072815
Thanks for the help!
I'm seeing the jumper, but I'm not sure to bridge 8 or 16 as my matrix is not labeled. Its the 64x64 with 2mm pitch IIRC.
Datasheet here:
https://cdn-shop.adafruit.com/product-f ... 21__1_.pdf
Deep90
Post by Deep90 »
Online sources seemed to point at 8 as the correct jumper. I went ahead and tried it and its working now!
dastels
Post by dastels »
Awesome!
Deep90
Post by Deep90 »
Thanks again for the help :)
