#include <Arduino.h>
#define int_pin1 13
#define led 17
void handle_irq3(void);
void handle_irq3(void) {
Serial.println("interrupt started");
digitalWrite(led, HIGH);
delay(1000);
digitalWrite(led, LOW);
delay(1000);
Serial.begin(9600);
Serial.println("External Interrupter ");
pinMode(led, OUTPUT);
pinMode(int_pin1, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(int_pin1), handle_irq3, FALLING);
Serial.println("interrupt ");
delay(500);
Hi, here I am using nrf52832 controller, above is the example code for external interrupt but unfortunately it is not working properly. When button is pressed the code stops inside the handle_irq3 function, led blink is not happening. Is there anything wrong inside the ISR function?? Refer the below attached output image
External Interrpt in nRF52832
- Pratyusha_duvvi
- Screenshot from 2022-08-02 17-48-57.png (133.51 KiB) Viewed 147 times
Last edited by Pratyusha_duvvi on Tue Aug 02, 2022 8:33 am, edited 2 times in total.
Re: External Interrpt in nRF52832
Serial I/O and delays are both problematic in an ISR. ISR code should be quick and do minimal work. Interrupts are typically disabled on entry, so you should avoid anything that requires the use of interrupts (such as serial I/O and delay).
One strategy that works for many cases is to simply set a flag and record whatever state is necessary, then process that on your next pass through the main loop.
- Pratyusha_duvvi
Thanks for your response. I also tried with flag but the problem is the interrupt process will only execute after the current process. what i need is when button pressed it should terminate the current process and execute the interrupt process.
An interrupt does not terminate anything. It just interrupts. The main loop will continue once you return from the interrupt.
Please post the code you are using,.
- Pratyusha_duvvi
Actually when i press button it should stop ledBlinking() and execute interrupt, after that the controller continue the current process but as per the above code when i press the button the interrupt will execute only after completing ledBlinking().
#define int_pin1 13
#define led 17
#define led1 19
#define led2 18
void interrupt();
void blink();
void ledBlinking();
bool pressButton = false;
Serial.begin(9600);
ledBlinking();
interrupt();
if(pressButton){
Serial.println("button pressed");
delay(500);
Serial.println("button Released");
delay(500);
void interrupt()
attachInterrupt(digitalPinToInterrupt(int_pin1), blink, FALLING);
void blink(void) {
if(digitalRead(int_pin1) == LOW)
pressButton = true;
void ledBlinking(){
for(int i=1; i<= 10; i++){
digitalWrite(led1, HIGH);
delay(500);
digitalWrite(led1, LOW);
delay(500);
Last edited by adafruit_support_bill on Wed Aug 03, 2022 5:29 am, edited 1 time in total.
Reason: Please use [code] tags when posting code to the forums.
the problem is that you are using delay() for timing. The delay() function prevents your code from being responsive to external events and is incompatible with any kind of real-time programming. You should use millis() instead for timing.
https://learn.adafruit.com/multi-taskin ... ino-part-1
https://learn.adafruit.com/multi-taskin ... ino-part-2
https://learn.adafruit.com/multi-taskin ... ino-part-3
Also, you only need to attach the interrupt once. You should move that code to your setup() function.
