Hi everyone!
I have a Adafruit LC709203F, which is brilliant! but i'm wondering if I can charge my battery with this device attached to it? The fuel gauge is designed to read a 3.7v battery and a charging board will likely push this voltage beyond this to charge up the battery.
Is it going to damage my LC709203F if I try to charge my battery with it reading the voltage? Do anyone know the absolute maximum voltage it can withstand?
Cheers
David
LC709203F & battery charging
- adafruit2
Re: LC709203F & battery charging
its totally ok! 3.7V is the nominal voltage, you can go up to 6V (but your battery will max at 4.2ish)
- david85
ah! excellent, thank you very much :)
