Battery Power
Battery Power
by aitneinc on Thu Jan 27, 2011 12:20 pm
Is it possible, through the use of regulators or series/parallel batteries, to use a 4.7v lithium-ion battery to power a 5VDC board? If so, what sort of circuitry would be required? Any help would be GREATLY appreciated.
aitneinc
Re: Battery Power
by zener on Thu Jan 27, 2011 1:20 pm
Chances are:
The specifications of the board allow the 5V to be low by some amount (translation: look at the specs of the board)
The 4.7V battery actually charges to some voltage higher than 4.7V
So that means: Just hook the battery to the board.
zener
Re: Battery Power
by franklin97355 on Thu Jan 27, 2011 2:44 pm
If you really do need 5v look into a boost converter.
franklin97355
