LithPoly Charger, Parallel batteries
by mobilewill on Sun Jan 30, 2011 3:59 pm
http://www.adafruit.com/index.php?main_page=product_info&cPath=44&products_id=280
Would it be safe to put 2 batteries in parallel with this charger? Would it but like charing one? I would be using 2 of the Sparkfun 6Ah batteries which is made of up 3 2Ah batteries.
mobilewill
Re: LithPoly Charger, Parallel batteries
by dbc on Sun Jan 30, 2011 5:23 pm
Did you check the data sheet? In general LiPo cells need to be managed individually.
dbc
by mobilewill on Sun Jan 30, 2011 5:25 pm
I know, but the battery is multiple cells but wired in a way that looks like 1 cell. So i figured I could add to that with another set. Wouldn't it be the same as the sparkfun 6Ah set? Seems like when my motors spike or try to go faster the battery shutdowns.
mobilewill
by adafruit_support_bill on Sun Jan 30, 2011 5:44 pm
The three cells in the SparkFun 6Ah battery are a matched set. There is no guarantee that the cells from two different sets will be matched.
by mobilewill on Sun Jan 30, 2011 5:50 pm
Thanks, my other option 2 chargers and then connect the outputs of the chargers together. to my project?
mobilewill
by adafruit_support_bill on Sun Jan 30, 2011 8:27 pm
For both charging and discharging, you want any cells in parallel to be matched.
by mobilewill on Sun Jan 30, 2011 8:28 pm
If I use 2 separate chargers wouldn't that be fine? as in one separate charger for each battery?
mobilewill
by adafruit_support_bill on Sun Jan 30, 2011 8:41 pm
"For both charging and discharging, you want any cells in parallel to be matched."
Charging with two chargers is fine. But if you connect them in parallel to power your project, (i.e. "discharging") you will have problems if the cells are not matched.
by mobilewill on Sun Jan 30, 2011 9:11 pm
That makes sense, thanks
mobilewill
