connector sourcing & matching smd 4 pins
by josheeg on Mon Feb 07, 2011 5:47 pm
connector sourcing & matching smd 4 pins...
If I had 16 small 1 inch boards and they needed a 4 pin smd connector to connect 4 wires to a main board.
The main board could be through hole but I don't know how to search in digikey & mouser to get matching parts.
I understand pitch but sometimes parts of a connector are shaped so others won't fit properly.
How have others done this 4 pins from 2 boards and it should be surface mount?
josheeg
Re: connector sourcing & matching smd 4 pins
by zener on Mon Feb 07, 2011 6:36 pm
Just depends what you have room for. You could do a 2x6 header and use a IDC ribbon connector. You could use mini usb. Could use a 1x4 header at .1" pitch and some mating connector.
zener
by josheeg on Mon Feb 07, 2011 7:59 pm
All Products » Interconnects » Rectangular Connectors » Headers & Wire Housings
mouser path male surface mount female IDC cable
This is the path before choosing male or female connector smd or idc ... so I am confused how to make shure they will fit etc.
What directorys I go down is one thing I wonder about.
josheeg
by josheeg on Mon Feb 07, 2011 10:11 pm
I like this female connector M22-6340442
now how do I know there is a male that goes to that with a ribbon cable? and another ribbon cable on the other side?
josheeg
by josheeg on Mon Feb 07, 2011 10:14 pm
are there any sugjestions for this with a crimp tool to insert in 4 pins that is universal?
josheeg
by zener on Tue Feb 08, 2011 3:04 am
I would use something like this, and just use a standard IDC connector on ribbon cable with it:
http://search.digikey.com/scripts/DkSea ... WM17449-ND
I would actually use the through hole version, but you wanted SMT.
zener
