Beating Heart Project.
by baddspella on Wed Feb 09, 2011 4:55 am
so iv built a proto tupe of a plushy heart that glows its heart beat. It has a potentiometer to controll the rate of wich the heart beats.
it works fine and all, but now i want to add a small servo to make the heart physicaly beat, with the glowing LED, but i also want the servo's beating to be controlled by the same POT that controlls the led.
im new to coding but i managed to merge my original code with the sweep example code.
but it just wont work.
LED heart beat on
int sensorPin = 0;    // select the input pin for the potentiometer
 int ledPin = 9;   // select the pin for the LED
 int sensorValue = 0;  // variable to store the value coming from the sensor
 void setup()  {
   // nothing happens in setup
 void loop()  {
   // This part need to stay as it was in the original code
   for(int fadeValue = 0; fadeValue <= 255; fadeValue +=5 ) {
     // sets the value (range from 0 to 255):
     analogWrite(ledPin, fadeValue);
     // sets the delay with the pot value
     delay(analogRead(sensorPin));
   // fade out from max to min in increments of 5 points:
   for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=5) {
LED heart beat + servo
#include <Servo.h>
Servo myservo; // create servo object to control a servo
int pos = 1;  // variable to store the servo position
 void setup()  {
  myservo.attach(10);  // attaches the servo on pin 10 to the servo object
 void loop()  {
  for(pos = 1; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(analogRead(sensorPin));                       // waits ??? for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
please if some one can help me and point out what iv done wrong?
or if some one can fix the code for me, im willing to sent $5 over paypal as a last resort.
-Gab
baddspella
Re: Beating Heart Project.
by adafruit_support_bill on Wed Feb 09, 2011 7:09 am
You should be more specific about what doesn't work.
Looking at the code, my guess would be that you get alternating 'beats' from the LED and the servo. You have 4 'for' loops that run sequentially. If you want the servo to move synchronously with the LED, you need to merge your servo code into the fade loops - something like this:
     int servoValue = map(fadeValue, 0, 255, 0, 180);  // map the fade value to the servo range
     myservo.write(servoValue);
by jdubrow on Wed Feb 09, 2011 11:05 am
What arduwino said. You may also want to have a delay after each beat as well to make it more life like. I always think of a heart beat occuring like: ___-_-___-_-___ (where a - is a beat and _ is idle).
jdubrow
