Background, im using a total of 9 xbees.
1.) Baudrate is set to 9600 on the xbee's and im using the arduino soft serial set to 9600.
2.) I have my PAN ID set to a non default number to ensure no rogue xbee's talk on my "channel"
3.) 1 xbee is the master, its pretty much listening to all the other nodes for data they are sending. its ATMY is set to 1, I did not set a specific ATDL, since if i need to i'd like it to talk to all the xbee's if needed.
4.) 8 xbee are data transmission nodes. All of them have an ATDL set to 1 to talk to only the master. They should NOT talk to each other. Each of them have a unique ATMY raning from 2 - 9.
So things are working fairly well in this setup for me. The nodes are very talkative and i have a feeling they're stepping on each other a little bit. So i want to tweak some of the radio paramaters. Given that, what are some good tweaks I should do?
Should I increase the baudrate from 9600 to 57600 or 115200 so that they send their data faster to prevent stepping on each other? Is there a down side to a higher baudrate? It seems like the higher the better..
I read that the default retry rate is 0 (so in a sense they act like UDP network packets). If i'd set a retry rate of 3, would that help to ensure the data gets there in case there was a "collission"
Lastly the max size string they send is about 40 ASCII characters (so 320 bytes?? send each time?). Should i set the ATRO to a higher number, not sure what the default size is.
Any tips from some xbee hardened vets?
