Hello!
I have TO3-P packages that I'd like to mount appropriately to heatskinks according to the following image:
I am having problem locating insulated bushings and regular bushings from my regular supplier (Mouser). Does anyone know where I can get some?
Heatsink mounting hardware
Re: Heatsink mounting hardware
http://mcmaster.com is worth a look, if it's a mechanical part, they probably have it. Otherwise, I'm not sure, sorry.
- zener
Keystone makes them. Called a #4 nylon shoulder washer. You can also use fiber. You use it with a #4 screw. http://search.digikey.com/scripts/DkSea ... sher+nylon
- jftheoret
Fantastic! Thank you very much. Exactly what I needed.Zener wrote:Keystone makes them. Called a #4 nylon shoulder washer. You can also use fiber. You use it with a #4 screw. http://search.digikey.com/scripts/DkSea ... sher+nylon
