I haven't tested it yet, but it looks like a library update was posted:
https://github.com/ladyada/Adafruit_CharacterOLED
http://adafruit.com/products/823
Blue OLED 16x2 Display not acting like LCD Versions
- techman
Re: Blue OLED 16x2 Display not acting like LCD Versions
The new library seems to work. I thought it failed one time, but it worked every other time. I am trying to modify the library to add support for the lcd backpack.
-tim
-tim
- rustybikes
I know I'm late to the party here, but I have also seen the problem where line 0 and 1 get swapped. Adding another data-point, the behaviour is different when powered via USB vs. external. It's been a while since I poked at this, but IIRC, on USB they're reversed. On external, they display as intended. Or maybe the other way round. I don't remember.
@techman - did you ever get the backpack working? I've a project that really really needs OLED, but I'm limited to SPI (maybe i2c) by the number of pins used on the Ardu by the shield in use.
- techman
Yes I was able to get it working with the backpack. I took the adafruit_LiquidCrystal library, made the write4bits public, and added the following. It's was brute force.rustybikes wrote:I know I'm late to the party here, but I have also seen the problem where line 0 and 1 get swapped. Adding another data-point, the behaviour is different when powered via USB vs. external. It's been a while since I poked at this, but IIRC, on USB they're reversed. On external, they display as intended. Or maybe the other way round. I don't remember.
The issue is the backpack does not implement the r/w line, so I was not able to completely implement the complete library as provided above. However it seems to work once the lcd is properly started up.
void setup(void) {
lcd.begin(16,2); // initialize the lcd
// Initialization sequence is not quite as documented by Winstar.
// Documented sequence only works on initial power-up. An additional
// step is required to handle a warm-restart.
// In the data sheet, the timing specs are all zeros(!). These have been tested to
// reliably handle both warm & cold starts
lcd.write4bits(0x03); // Missing step from doc. Thanks to Elco Jacobs
delayMicroseconds(5000);
lcd.write4bits(0x02);
lcd.write4bits(0x08);
lcd.command(0x08); // Turn Off
lcd.command(0x01); // Clear Display
lcd.command(0x06); // Set Entry Mode
lcd.command(0x02); // Home Cursor
lcd.command(0x0C); // Turn On - enable cursor & blink
lcd.home();
lcd.print("Booting...");
delay(1000);
lcd.print("Booted...");
- rustybikes
Well, it's a kind of progress, I guess...Yes I was able to get it working with the backpack. I took the adafruit_LiquidCrystal library, made the write4bits public, and added the following. It's was brute force.
Following your lead, I modified the Adafruit_LiquidCrystal library (provided in this thread) to let write4bits be public, and used your sample above to modify the HelloWorld_SPI example included in the library:
Demonstration sketch for Adafruit i2c/SPI LCD backpack
using 74HC595 SPI expander
( http://www.ladyada.net/products/i2cspilcdbackpack/index.html )
This sketch prints "Hello World!" to the LCD
and shows the time.
The circuit:
* 5V to Arduino 5V pin
* GND to Arduino GND pin
* CLK to Digital 2
* DAT to Digital 3
* LAT to Digital 4
// include the library code:
#include "Wire.h"
#include "LiquidCrystal.h"
// Connect via SPI. Data pin is #3, Clock is #2 and Latch is #4
LiquidCrystal lcd(3, 2, 4);
// set up the LCD's number of rows and columns:
lcd.home();
delay(1000);
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
// print the number of seconds since reset:
lcd.print(millis()/1000);
lcd.setBacklight(HIGH);
//delay(500); // Seizure-inducing. Plus, it's not needed for OLED.
//lcd.setBacklight(LOW);
//delay(500);
I call it progress, 'cos I get more than a single "H" now, and I do see the pattern shift every second as the loop() runs, but I'm not quite "there" yet. FWIW, the LCD works fine with the unmodified example sketch, but it also displays garbage with the additions you posted, so it's clearly doing something.
Maybe something'll happen if I poke around at the timings even further. I'm new enough to this scene that I'll probably cause more harm than good, but that's what backups are for..
These displays are tricky to work with. I've got them to work without using the R/W line, but not very consistently. And once they get out of sync, the only way to reliably recover is to power cycle them.
- rustybikes
Quoted for truth. These little OLED 16x2's are great when you get them to work correctly (i.e. not SPI/i2c), but they are only "mostly" HD44780-compatible.adafruit_support wrote:These displays are tricky to work with. I've got them to work without using the R/W line, but not very consistently. And once they get out of sync, the only way to reliably recover is to power cycle them.
I don't want to further derail the thread, but I thought I'd report progress on my project. I didn't mention it the other day, but it's the beginning of a car-computer based on the CAN-BUS shield from SparkFun. Until I figured out the OLED, I popped one of the LCDs on. I had been using a red-on-black LCD, but switched to white-on-blue. That improved the readability rather dramatically, plus (big win) I've tweaked the code to allow me to set the backlight level using the joystick, so it's actually better than OLED, especially for night-drives.
One of my next projects is to use an Ardu with a GPS receiver as a bicycle computer. In that context, I still think OLED would be more suitable. Plus, I'll play with the LINE0/LINE1 reversal behaviour some more. Maybe I'll even stop derailing the thread and contribute something on-topic...
- uhclem
My attempt at modifying the Adafruit_CharLCD.py library for the Pi. It's not working any better than the original and I am not sure why. The linefeeds seem to be ignored and the characters are too close to each other. I've got the r/w pin grounded since in the Arduino library it never seems to leave the LOW state.
#!/usr/bin/python
# based on code from lrvick and LiquidCrystal
# lrvic - https://github.com/lrvick/raspi-hd44780/blob/master/hd44780.py
# LiquidCrystal - https://github.com/arduino/Arduino/blob/master/libraries/LiquidCrystal/LiquidCrystal.cpp
# Changes based on the Adafruit_CharacterOLED library
import RPi.GPIO as GPIO
from time import sleep
class Adafruit_CharLCD:
# commands
LCD_CLEARDISPLAY = 0x01
LCD_RETURNHOME = 0x02
LCD_ENTRYMODESET = 0x04
LCD_DISPLAYCONTROL = 0x08
LCD_CURSORSHIFT = 0x10
LCD_FUNCTIONSET = 0x20
LCD_SETCGRAMADDR = 0x40
LCD_SETDDRAMADDR = 0x80
# flags for display entry mode
LCD_ENTRYRIGHT = 0x00
LCD_ENTRYLEFT = 0x02
LCD_ENTRYSHIFTINCREMENT = 0x01
LCD_ENTRYSHIFTDECREMENT = 0x00
# flags for display on/off control
LCD_DISPLAYON = 0x04
LCD_DISPLAYOFF = 0x00
LCD_CURSORON = 0x02
LCD_CURSOROFF = 0x00
LCD_BLINKON = 0x01
LCD_BLINKOFF = 0x00
# flags for display/cursor shift
LCD_DISPLAYMOVE = 0x08
LCD_CURSORMOVE = 0x00
LCD_MOVERIGHT = 0x04
LCD_MOVELEFT = 0x00
# flags for function set
LCD_8BITMODE = 0x10
LCD_4BITMODE = 0x00
LCD_2LINE = 0x08
LCD_1LINE = 0x00
LCD_5x10DOTS = 0x04
LCD_5x8DOTS = 0x00
def __init__(self, pin_rs=25, pin_e=24, pins_db=[23, 17, 21, 22]):
self.pin_rs = pin_rs
self.pin_e = pin_e
self.pins_db = pins_db
GPIO.setmode(GPIO.BCM)
# set the control pins as outputs
GPIO.setup(self.pin_e, GPIO.OUT)
GPIO.setup(self.pin_rs, GPIO.OUT)
# set the data pins as outputs
for pin in self.pins_db:
GPIO.setup(pin, GPIO.OUT)
# pull the control pins low
GPIO.output(self.pin_rs, False)
GPIO.output(self.pin_e, False)
# special setup sauce
self.write4bits(0x03)
self.delayMicroseconds(5000)
self.write4bits(0x02)
self.write4bits(0x08)
# turn off
# clear display
self.write4bits(0x01)
# set entry mode
self.write4bits(0x06)
# home cursor
# turn on - enable cursor and blink
self.write4bits(0x0c)
def begin(self, cols, lines):
if (lines > 1):
self.numlines = lines
self.displayfunction |= self.LCD_2LINE
self.currline = 0
def home(self):
self.write4bits(self.LCD_RETURNHOME) # set cursor position to zero
self.delayMicroseconds(2000) # this command takes a long time!
def clear(self):
self.write4bits(self.LCD_CLEARDISPLAY) # command to clear display
self.delayMicroseconds(2000) # 2000 microsecond sleep, clearing the display takes a long time
def setCursor(self, col, row):
self.row_offsets = [ 0x00, 0x40, 0x14, 0x54 ]
if ( row > self.numlines ):
row = self.numlines - 1 # we count rows starting w/0
self.write4bits(self.LCD_SETDDRAMADDR | (col + self.row_offsets[row]))
def noDisplay(self):
""" Turn the display off (quickly) """
self.displaycontrol &= ~self.LCD_DISPLAYON
self.write4bits(self.LCD_DISPLAYCONTROL | self.displaycontrol)
def display(self):
""" Turn the display on (quickly) """
self.displaycontrol |= self.LCD_DISPLAYON
def noCursor(self):
""" Turns the underline cursor on/off """
self.displaycontrol &= ~self.LCD_CURSORON
def cursor(self):
""" Cursor On """
self.displaycontrol |= self.LCD_CURSORON
def noBlink(self):
""" Turn on and off the blinking cursor """
self.displaycontrol &= ~self.LCD_BLINKON
def noBlink(self):
def DisplayLeft(self):
""" These commands scroll the display without changing the RAM """
self.write4bits(self.LCD_CURSORSHIFT | self.LCD_DISPLAYMOVE | self.LCD_MOVELEFT)
def scrollDisplayRight(self):
self.write4bits(self.LCD_CURSORSHIFT | self.LCD_DISPLAYMOVE | self.LCD_MOVERIGHT);
def leftToRight(self):
""" This is for text that flows Left to Right """
self.displaymode |= self.LCD_ENTRYLEFT
self.write4bits(self.LCD_ENTRYMODESET | self.displaymode);
def rightToLeft(self):
""" This is for text that flows Right to Left """
self.displaymode &= ~self.LCD_ENTRYLEFT
def autoscroll(self):
""" This will 'right justify' text from the cursor """
self.displaymode |= self.LCD_ENTRYSHIFTINCREMENT
def noAutoscroll(self):
""" This will 'left justify' text from the cursor """
self.displaymode &= ~self.LCD_ENTRYSHIFTINCREMENT
def write4bits(self, bits, char_mode=False):
""" Send command to LCD """
self.delayMicroseconds(1000) # 1000 microsecond sleep
bits=bin(bits)[2:].zfill(8)
GPIO.output(self.pin_rs, char_mode)
GPIO.output(pin, False)
for i in range(4):
if bits[i] == "1":
GPIO.output(self.pins_db[::-1][i], True)
self.pulseEnable()
for i in range(4,8):
if bits[i] == "1":
GPIO.output(self.pins_db[::-1][i-4], True)
# added 50 us delay
self.delayMicroseconds(50)
self.pulseEnable()
def delayMicroseconds(self, microseconds):
seconds = microseconds / 1000000 # divide microseconds by 1 million for seconds
sleep(seconds)
def pulseEnable(self):
self.delayMicroseconds(1) # 1 microsecond pause - enable pulse must be > 450ns
GPIO.output(self.pin_e, True)
# changed to 50 us
self.delayMicroseconds(50) # 1 microsecond pause - enable pulse must be > 450ns
self.delayMicroseconds(1) # commands need > 37us to settle
def message(self, text):
""" Send string to LCD. Newline wraps to second line"""
for char in text:
if char == '\n':
self.write4bits(0xC0) # next line
else:
self.write4bits(ord(char),True)
if __name__ == '__main__':
lcd = Adafruit_CharLCD()
lcd.clear()
lcd.message(" Adafruit 16x2\n Standard LCD")
As mentioned two posts up, you need to use the R/W line with these displays.I've got the r/w pin grounded since in the Arduino library it never seems to leave the LOW state.
- uhclem
Ah there it is in Adafruit_CharacterOLED::waitForReady - it goes high there. I'll post the python code once I get it working.
Thanks! I can't wait to see this work. A regular LCD literally "pales" in comparison!
- uhclem
Not quite working. I get the feeling it's still not getting properly initialized. I'll see if I can catch the rw pin and d7 doing their thing (or not) on my scope.
Try including the wire library first.
Then include the LCD library.
Saw that on another website.......
#include <Wire.h>
#include <LiquidCrystal.h>
#include <Wire.h>
- uhclem
Getting pretty close:
Here's my code (don't forget this is python meant for python GPIO library on the Raspberry Pi):
On a cold power-up it does not work right but after that it does. I still have to figure out why there is no space between the characters. I think the other artifacts are due to a damaged display. I might have been too rough desoldering it from the serial backpack it came with.Here's my code (don't forget this is python meant for python GPIO library on the Raspberry Pi):
#!/usr/bin/python
class Adafruit_CharOLED:
# commands
LCD_CURSORON = 0x02
LCD_BLINKON = 0x01
LCD_BLINKOFF = 0x00
LCD_MOVELEFT = 0x00
LCD_8BITMODE = 0x10
LCD_4BITMODE = 0x00
LCD_2LINE = 0x08
LCD_1LINE = 0x00
LCD_5x10DOTS = 0x04
LCD_5x8DOTS = 0x00
def __init__(self, pin_rw=18, pin_rs=25, pin_e=24, pins_db=[23, 17, 21, 22]):
self.pin_rw = pin_rw
self.pin_e = pin_e
GPIO.setup(self.pin_rw, GPIO.OUT)
GPIO.output(self.pin_rw, False)
self.busy_pin = 22
# copied from Adafruit_CharacterOLED.cpp
self.write4bits(0x03, True)
self.write4bits(0x02, True)
self.write4bits(0x08, True)
# self.write4bits(0x33) # initialization
# self.write4bits(0x32) # initialization
# self.write4bits(0x28) # 2 line 5x7 matrix
# self.write4bits(0x0C) # turn cursor off 0x0E to enable cursor
# self.write4bits(0x06) # shift cursor right
self.displaycontrol = self.LCD_DISPLAYON | self.LCD_CURSOROFF | self.LCD_BLINKOFF
self.displayfunction = self.LCD_4BITMODE | self.LCD_1LINE | self.LCD_5x8DOTS
""" Initialize to default text direction (for BANNED languages) """
self.displaymode = self.LCD_ENTRYLEFT | self.LCD_ENTRYSHIFTDECREMENT
self.write4bits(self.LCD_ENTRYMODESET | self.displaymode) # set the entry mode
self.clear()
if (lines > 1):
self.currline = 0
def waitForReady(self):
self.busy = True
GPIO.setup(self.busy_pin, GPIO.IN)
GPIO.output(self.pin_rw, True)
while True:
self.delayMicroseconds(10)
self.busy = GPIO.input(self.busy_pin)
self.pulseEnable()
if (self.busy == False):
break
GPIO.setup(self.busy_pin, GPIO.OUT)
def home(self):
def clear(self):
def display(self):
def noCursor(self):
def cursor(self):
""" Cursor On """
def noBlink(self):
def noBlink(self):
for i in range(4):
if bits[i] == "1":
self.pulseEnable()
if bits[i] == "1":
self.pulseEnable()
self.waitForReady()
sleep(seconds)
for char in text:
if char == '\n':
else:
lcd = Adafruit_CharOLED()
lcd.clear()
- uhclem
I am glad this was helpful. I don't recall having problems with the second line.
Someone has definitely figured this display out, since I have used it with a serial backpack which somehow spaces the characters properly and knows how to get big characters as well. Just a question of if they will share how they did it.
