How to capture and send audio to another interface (Visual Basic or Delphi)
by luiz_antoniosp on Wed Aug 07, 2013 5:36 pm
I Do 2 control line through the Arduino telephonic Duelamilanove
Using ports Digital Audio However these online'm sending to
recording the microphone input of the sound card of the PC.
I would send these two channels of audio (8bit Mono Each)
the analog ports of the Arduino, sending these audio data for some
place the computer where I can capture this audio buffer
through my interface and then do the Recording file individually
each telephone line.
luiz_antoniosp
Re: How to capture and send audio to another interface (Visual Basic or Delphi)
by adafruit_support_bill on Wed Aug 07, 2013 7:24 pm
Hi. I' have moved this topic to a more appropriate forum.
From your post, it is not clear what Adafruit products you are using. Please provide more detail about what you are trying to accomplish.
by luiz_antoniosp on Wed Aug 07, 2013 8:04 pm
luiz_antoniosp wrote:Hello,
Watch this video
  http://brohogan.blogspot.com.br/search?q=telephone
the audio comes through the microphone input of the computer
however I want the audio from this:
ANALOG_ARDUINO> USB> SERIAL> MY inteface
What I want to know is:
* How can I capture audio data that travels in arduino and send
for an interface in Delphi.
* How do I intend to send two signal lines telefonica want to know
* How to do this since I have two audio line
  8bits each and arduino only have 10bits:
The solution would be to use this:
http://www.adafruit.com/products/1085
However I do not know how to do;
luiz_antoniosp
by adafruit_support_bill on Wed Aug 07, 2013 8:46 pm
The ADS 1115 is a high-resolution device. However the maximum sample rate is 860 Hz, so it is not suitable for audio.
USB/Serial is also not well suited for audio transfer. The maximum data rate is about 11KHz, but with only 8-bit resolution. That is relatively low-quality audio. The bigger problem would be the latency and jitter inherent in the USB/Serial data transfer. Good quality audio is possible over USB using the isochronous transfer mode. But that is not a capability native to the Arduino.
