RGB values received from TCS34725
Re: RGB values received from TCS34725
by Systembolaget on Fri Sep 21, 2018 4:16 am
Here is the final code I used. Works well with very many colours, also pastel ones that others seem to have difficulty differentiating. Most important is a matt black rectangular shroud around the Adafruit breakout-board to stop any light ingress that would otherwise influence the sample's illumination. Hope it helps.
/******* Tutorial 6a. Colour finder and sorter *******/
/******* Adafruit Metro Mini, ams TCS34725 *******/
/******* LIBRARIES *******/
#include <Wire.h>
#include "Adafruit_TCS34725.h"
#include "Servo.h"
/******* VARIABLES *******/
const int SAMPLES[14][5] = { // Values from colour training (averaged raw r, g and b; actuator movement)
  {8771, 6557, 3427,  10},
  {7013, 2766, 1563,  20},
  {4092, 1118, 1142,  30},
  {4488, 1302, 1657,  40},
  {3009, 1846, 2235,  50},
  {7546, 6686, 6323,  60},
  {2650, 3139, 4116,  70},
  { 857,  965, 1113,  80},
  {2926, 5012, 5331,  90},
  { 964, 2014, 2418, 100},
  {1260, 2200, 1459, 110},
  {4784, 5898, 3138, 120},
  {5505, 5242, 2409, 130},
  {5406, 3893, 1912, 140}, // When adding samples, no particular order is required
bool sensorTriggered = false; // Sample present yes or no
byte samplesCount = sizeof(SAMPLES) / sizeof(SAMPLES[0]); // Determine number of samples in array
const byte pinLED = A0; // Connect ams TCS34725 breakout board LED pin to pin A0 on Adafruit Metro Mini
Adafruit_TCS34725 tcs = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_700MS, TCS34725_GAIN_1X); // Longer integration time for higher colour sensing fidelity
Servo HD1900A;
/******* FUNCTIONS *******/
void setup(void) {
  Serial.begin(9600);
  pinMode (pinLED, OUTPUT);
  HD1900A.attach(3); // Connect servo to pin 3 on Adafruit Metro Mini
  HD1900A.write(0); // Rotate to initial position
} // End of setup
void loop(void) {
  digitalWrite(pinLED, HIGH); // Turn on-board LED on; set to LOW to turn off or when using alternative illumination
  uint16_t r, g, b, c;
  tcs.getRawData(&r, &g, &b, &c); // Change Adafruit_TCS34725.cpp line 223 to omit &c (only needed for colour temperature and Lux calculation)
  byte foundColour = findColour(r, g, b);
  if (sensorTriggered) {
    HD1900A.write(SAMPLES[foundColour][3]); // Rotate servo to matching position
  } else {
    Serial.println("No swatch present!"); // Or buzzer?
    //HD1900A.write(0); // Rotate to initial position
} // End of loop
byte findColour(int r, int g, int b) {
  int distance = 10000; // Raw distance from white to black (change depending on selected integration time and gain)
  byte foundColour;
  for (byte i = 0; i < samplesCount; i++) {
    int temp = sqrt(pow(r - SAMPLES[i][0], 2) + pow(g - SAMPLES[i][1], 2) + pow(b - SAMPLES[i][2], 2)); // Calculate Euclidean distance between colours
    if (temp < distance) {
      distance = temp;
      foundColour = i;
  if (distance > 500) { // Threshold distance from SAMPLES calibration process
  } else {
    sensorTriggered = true;
  return foundColour;
} // End of findColour
Systembolaget
by adafruit_support_bill on Fri Sep 21, 2018 5:40 am
Thanks for sharing your code!
by mirz11 on Mon Oct 01, 2018 2:26 am
Systembolaget wrote:Here is the final code I used. Works well with very many colours, also pastel ones that others seem to have difficulty differentiating. Most important is a matt black rectangular shroud around the Adafruit breakout-board to stop any light ingress that would otherwise influence the sample's illumination. Hope it helps.
#include <Wire.h>
#include "Servo.h"
Servo HD1900A;
void setup(void) {
  Serial.begin(9600);
} // End of setup
void loop(void) {
  } else {
} // End of loop
  byte foundColour;
      distance = temp;
      foundColour = i;
  } else {
  return foundColour;
Thank you for sharing the code!
mirz11
