Sammyk22 wrote:Where you are entering the {23Key} etc how do I get there? I have made the necessary changes in the .cfg file but I am having a heck of a time getting to where I can edit these keys. I'm using F4 and trying to locate the retrogame.c file there. Am I in the wrong place?
cd /boot
sudo nano retrogame.cfg
this will pop up
# Sample configuration file for retrogame.
# Really minimal syntax, typically two elements per line w/space delimiter:
# 1) a key name (from keyTable.h; shortened from /usr/include/linux/input.h).
# 2) a GPIO pin number; when grounded, will simulate corresponding keypress.
# Uses Broadcom pin numbers for GPIO.
# If first element is GND, the corresponding pin (or pins, multiple can be
# given) is a LOW-level output; an extra ground pin for connecting buttons.
# A '#' character indicates a comment to end-of-line.
# File can be edited "live," no need to restart retrogame!
# Here's a pin configuration for the PiGRRL 2 project:
LEFT 4 # Joypad left
RIGHT 19 # Joypad right
UP 16 # Joypad up
DOWN 26 # Joypad down
LEFTCTRL 14 # 'A' button
LEFTALT 15 # 'B' button
Z 20 # 'X' button
X 18 # 'Y' button
SPACE 5 # 'Select' button
ENTER 6 # 'Start' button
A 12 # Left shoulder button
S 13 # Right shoulder button
ESC 17 # Exit ROM; PiTFT Button 1
1 22 # PiTFT Button 2
2 23 # PiTFT Button 3
3 27 # PiTFT Button 4
# For configurations with few buttons (e.g. Cupcade), a key can be followed
# by multiple pin numbers. When those pins are all held for a few seconds,
# this will generate the corresponding keypress (e.g. ESC to exit ROM).
# Only ONE such combo is supported within the file though; later entries
# will override earlier.
the bottom 4 pins are the TFT buttons
