ATtiny817 seesaw as an I2C to UART bridge?
steveputz
Post by steveputz »
Am I correct that the UART module is not configured in the pre-burned seesaw firmware?
Specifically the ATtiny817 seesaw version breakout? https://www.adafruit.com/product/5233
I would like to add an additional hardware UART to an ESP32 project where I'm also short on GPIO/ADC pins, so using a seesaw with pre-burned firmware to get these via I2C would be convenient.
If I have to write and load custom firmware into the ATtiny to create an I2C to UART bridge, it's not as convenient.
mikeysklar
Re: ATtiny817 seesaw as an I2C to UART bridge?
Post by mikeysklar »
Looking at the SeeSAW commits I see UART functionality is present. Still without examples plus enabling and compiling it could be a big detour.
Which ESP32 are you using? The Feather V2 (Pico based) has three UARTs.
steveputz
Post by steveputz »
I'm very familiar with the Feather V2.
For this project I'm using a non-Adafruit ESP32 board (with a SIM7000 cellular modem on the same board).
It is an ESP32-wrover with 3 UARTs, but I need a total of 4 serial connections for my application (including the USB debug serial, which I'm reluctant to give up). I'm currently filling the gap with software serial (which I don't entirely trust).
When you write "enabling and compiling it could be a big detour", do you mean the UART seesaw code is in github, but not included in the pre-programmed multifunction seesaw units shipped from Adafruit?
I was hoping not to have to reprogram the ATtiny, and also hoping to have example code.
I will likely incorporate a pre-programmed ATtiny seesaw in my project to get more GPIO and ADC, but also getting hardware UART via I2C would be a bonus. I cannot tell from the seesaw sources on github whether enabling UART will still allow GPIO And ADC via seesaw as well.
mikeysklar
This SeeSaw UART will not be convenient. It will require recompiling, programming and there are no examples I can find to use it.
If you need a lot of UARTs does it make sense and bring in another controller? You are familiar with the Feather V2 which would buy you more UARTs.
In some cases giving up a single UART is not so bad if you have a debug port and a J-Link. The Metro ESP32-S3 includes a 2x5 SWD connector. There are other variations on specific ESP32 modules.
