Help with fixing code
Microsoft's MakeCode platform for easy blocks-style programming
Post Reply
DazednConfused
Post by DazednConfused »
So I have a LED strip that I need to slowly fade from color to color.
I found this code and entered into MakeCode. It says Line 22: ';" expected. I tried putting it everywhere in the line but it still says there's an error.
define, TRANSITION_MILLIS, 5000
byte, colSrc[3], colDst[3], colCur[3]; //R=0, G=1, B=2
byte, idx; //used as global indexer
unsigned, long, transitionStart, transitionPos;
void randomColor(byte * col)
    for (idx = 0; idx < 3; i++) col[idx] = random(256);
void setup()
    randomSeed(analogRead(A0));
    randomColor(colSrc);
    randomColor(colDst);
    transitionStart = millis();
void loop()
    unsigned long; loop;Ms = millis();
    transitionPos = loopMs - transitionStart;
    if (transitionPos >= TRANSITION_MILLIS) {
        //done
        memcpy(colSrc, colDst, sizeof(colDst)); //copy dst to src
        memcpy(colCur, colDst, sizeof(colDst)); //set current color
        randomColor(colDst); //new dst
        transitionStart = loopMs;
    else {
        //in progress
        for (idx = 0; idx < 3; idx++) colCur[idx] = map(transitionPos, 0, TRANSITION_LENGTH - 1, colSrc[idx], colDst[idx]);
    //Here "colCur" is the current RGB value of the transition
mikeysklar
Re: Help with fixing code
Post by mikeysklar »
@DazednConfused,
Are you really using MakeCode, because this looks like C.
What hardware are you using? Controller board and LED strip model.
If you were using Makecode I would just use 'set strip brightness <value>' code block in a loop going up and down with a delay to see the fade.
DazednConfused
I put it into make code but I guess it's Javascript?
I have a Gemma M0 and LED strip lights you get from the store
mikeysklar
I take it the strip lights are not from the Adafruit store? We can help you with the Adafruit neopixels and dotstars, but you will have to make a go of things on your own with other devices.
DazednConfused
No they are not. Thank you!
Post Reply
Return to “MakeCode”
