Trinket m0 Intellectual Property Protection
Post Reply
Serifin
Post by Serifin »
I have been working on a project that requires intellectual property protection to be in place. I checked the data sheet for the samd21 chip and it happens to have an Intellectual Property Protection system that can be accessed. This is done by setting the NVMCTRL security bit. This sets a security bit in the CTRLA register. This is done by writing to the CMDEX and CMD registers.
I have a few questions that I have been having trouble finding the answer to, and I’m hoping I can get some guidance or answers here.
1.)Is there a simple way to set the security bit through the arduino ide, or within the arduino code itself, or to accomplish something similar?
2.a.)Is the trinket m0 capable of doing this? (I found in the adafruit-trinket-m0-circuitpython-arduino.pdf that it doesn't have NVM since“... we use the internal flash for disk …”)
2.b.) If the answer to 2.a. is no, could I make a new UF2 Bootloader to get around this or am I misunderstanding the role the Bootloader plays in the operation of this board?
danhalbert
Re: Trinket m0 Intellectual Property Protection
Post by danhalbert »
There is discussion in these search results, but there is not a way to do it in the Arduino IDE directly that I see.
https://www.google.com/search?q=arduino ... curity+bit
That `nvm` is the CircuitPython module named `nvm`, not NVM in general. So that quote is not relevant in this case. The Trinket M0 uses a SAMD21, and is not inherently prevented from setting the security bit.
The bootloader wouldn't do this unless you set it up to set the security bit after loading a program. Once the security bit is set, the only way to clear it is to do a complete chip erase.
Serifin
Post by Serifin »
Thank you for the reply, I will hopefully be able to try the method detailed in the discussion you linked some time in the next 2 days.
Post Reply
