Adafruit_sdcard
Post Reply
slemieux99
Adafruit_sdcard
Post by slemieux99 »
Hi All.
The Device i have
UF2 Bootloader v2.0
Model: Raspberry Pi RP2
Board-ID: RPI-RP2
Adafruit CircuitPython 8.2.9 Raspberry Pi Pico with rp2040
i am trying to read/write to MicroSD, every time i run the script i get the same error.
File "<stdin>", line 1, in <module>
ImportError: no module named 'sdcard'
not sure whats up, would appreciate any help to resolve this,
dastels
Re: Adafruit_sdcard
Post by dastels »
You need to copy the sdcard library to CIRCUITPY/lib, i.e. adafruit_sdcard.mpy
danhalbert
Re: Adafruit_sdcard
Post by danhalbert »
You could use the builtin module `sdcardio` instead, as well.
slemieux99
Re: Adafruit_sdcard
dastels wrote: Fri Feb 09, 2024 1:40 pm You need to copy the sdcard library to CIRCUITPY/lib, i.e. adafruit_sdcard.mpy
Hi i did copy the library to the lib folder on the CIRCUITPY Drive, in the Lib folder, the file is in the root lib folder,
but still get the same error
slemieux99
Re: Adafruit_sdcard
danhalbert wrote: Fri Feb 09, 2024 2:15 pm You could use the builtin module `sdcardio` instead, as well.
would you have an example of this, and what is needed to use it.
dastels
Re: Adafruit_sdcard
Post by dastels »
slemieux99
Re: Adafruit_sdcard
yes i do please
dastels
Re: Adafruit_sdcard
Post by dastels »
I encourage you to use sdcardio.
In either case, see https://learn.adafruit.com/adafruit-mic ... cuitpython for details and example code.
Post Reply
